  • Replies 130
Guest Robo's
Its interesting that people seem to thinkthe injectors are good for 250rwkw.  I can be done, but how many people have been running 250rwkw on stock rb25 injectors and not needed a rebuild?
I really do think if you are trying to skimp on the cost of mods, you will either end up with a dog, or it will only cost you more in the long run. You get what you pay for.
but hey, its not my car.
So if the motor is tuned properly with good A/F ratios, how can the injectors make you need a rebuild?
Trust33 : there are plenty of threads on this topic at the moment,
I do not use an oil cooler, but 1 would planned in the near future.
Injectors are good for about 250rwkw. Maybe more or less depending on other mods to your vehicle, such as fuel pressure regulator, aftermarket fuel pump ect..
Just have a read about..
The injectors dont, the lack of fuel does. I know, there is all this theory around how you can run 250+ rwkw with stock injectors - but how many cars have you seen sustain this and keep their ringlands in one piece. My injectors were at 85% with 200rwkw, right on the edge, tuned with 12:1 af ratios. This was on a warm 35deg C day.
Its not just the AF ratios at the time the car is tuned that needs to be considered - what about temperature change or accel enrichment?
Everyone blames the weak ringlands of the RB25, well I am not the only one with over 300rwkw on stock pistons, the ring lands are not that weak.
but like I said, if you think you can do something no one else can, go for it. I am just putting up a word of caution for those who care to consider it. At the end of the day its not my car. I would just like to see evidence when someone says xxx power with stock injectors is no probs. I think without good evidence, its misleading and could result in a very expensive problem.
knore, you may be running only 14 psi, but that means squat. Power is relative to air flow,which is relative to the amount of fuel needed. 14psi boost can mean anything until you get it on a dyno. two turbos with the same boost pressure on different engines can make different power.
The internet is a great place to find information, I just think its also a great place to be lead up the garden path. It is therefore, for me, very important that I see some sort of evidence before I believe what others say, ESPECIALLY when I have seen alot of evidence that says otherwise.
the GCG option is easily the simplest, but not the cheapest if your get a 2nd hand hks turbo, but then obviously its not new! So basically i would only consider a 2nd hand turbo if it was very well priced and in excellent condition..
As far as looking stock is concerned, youd have to look pretty damn close to pick an HKS 25** sitting down there instead of the stocker. Put the heat shield back on and your definitly not gonna tell.
from what i hear the stock fuel pump becomes unreliable at 200rwkw and above.
As far as the stock injectors go, ive been running mine flat chat for just over 5000kms with injector duty constantly between 95 and 100%. I have a reg but the tuner didnt bump up the pressure when he tuned it, as it only reached mid 80's on the dyno... Recipe for disaster, maybe!
Everyone says dont run over 80% efficiency, obviously this is so you have some fueling capability in reserve, but can someone who knows the actual technical reason tell me why if my absolute max peak duty is just under 100%, and AFRS are fine, knock is fine, what is wrong with running such a high duty cycle? do the injectors wear out or something? Is my setup a time bomb in its current high duty-cycle state?
Thanks LEPPERFISH so as i understand it to get the most from std injectors a fuel preassure regulator is needed @ arround 180rwkw and upward to 200rwkw.Where then it would be wise to get a fuel pump @200rwkw and up.ive seen the thread and it states that when an injector is pushed to its limits it can not deliver enough fuel into the chamber in some circumstances and cause detonation @ the 220rwkw power level im aiming @.Im keen to know if feeding it injector cleaner regularly enough will combat this problem
:werd: I couldnt agree more.
Double :werd:
My injectors were being pushed at 210rwkw... taking them to 250rwkw is just playing with fire and asking for trouble... and as many here have found, trouble is certainly there waiting for ya.
Dont cut corners, it will only cost you more pain in the end.
We have one on the GTR, one on the GTST and one on the GTT.  But the Stagea is an auto so it gets an SAFC, better than nothing.
Ya, better than nothing, never said it was useless... you just wanted some rice SK :P:P:rant:
you have 6 injectors and 6 cylinders - it only takes a lean out in 1 injector to f&*^ your engine?
i draw samples from my wrx experiences. the EJ20 block is layed out with 2 horizontally opposed pistons. the fuel rail runs all the way around the block to feed each cylinder. the drawback of this design is quite apparent - the first cylinder on the fuel rail is always rich, the last cylinder can potentially suffer from fuel starvation.
when you start pushing the limits of the EJ20, the A/F ratios don't tell the full story, and this is when wrx owners should be most wary. the chance of fuel starvation on that last cylinder increases dramatically. ask wrx fans which cylinder is most popular to blow its ringland and it will be cylinder #2 - not coincedentally the last cylinder on the fuel rail.
the solution? they split the fuel rail and run fuel rails down both sides of the block with 2 fuel regulators...my point is, a/f ratios might not tell you the whole truth - be wary of the weakest links...
Most people can do it I think.. Yes the 550cc injectors are cheaper and compatable but as someone here said before, the cheaper option isnt always the best option in the long run.
PM SydneyKid, he's quite knowlogable on the subject, and everything else about Skylines. LOL..
I wouldnt push the stock injectors past 200rwkw mine were in the 90's with a 044 pump at 208rwkw. using a regulator to push them beyond this point may seem like quick fix to get better air fuel ratios but it will force the injectors to give a very poor spray patten. So its not very efficiant in keeping conbustion temps in control but will still give a air fuel ratio that may be the same as if you were to upgrade and this is were people think theres no point in spending the money.
Im also not a big fan of using rotor injectors as they they are said to have unusual spray patterns, but I dont know of any people breking engines like i have herd of many cases with stock injectors reg'd 25's
i would even up the boost on a rb with out doing fuel pump if you have 90000km.. it could fail.. boom! i would do the support mods - fuel pump, fuel reg, intercooler, exhaust, cams if you wish cam gears if you wish too and after that get your turbo and ecu at the same time and tune.. either that or tune it twice if you buy the ecu early in the mod process.. while you have everything else you mite find out the turbo you were going to buy doesnt make the power you want or have the powerband you want. do it right the first time and reap the benifits later
The GCC 450hp Turbo ,, Do you know if they use the STD exhaust housing or a VG30 exhaust housing ... To me it looks like a Standard RB25 exhaust housing and that is why they back cut the turbine wheel ,,,  Hmmm any Ideas SydneyKid  ??
Im also interested to know
looks to me they still use the standard compressor and exhaust housing but machined out to take bigger turbine & compressor wheel..
some sort of T04?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
