Hi Guys
I put my car on a dyno yesterday & was told its pinging right at the top of the rev range.
Its pretty much standard apart from exhaust, filter & boost controller which was set on 8psi for the run.
I suspect its pinging due to the timing being out. The fuel to air ratio was fine at 11.2 pretty much all along the rev range.
My question is can any one confirm if the plastic R34gtt bottom timing cover is different to the metal ones previously used on 32 & 33's.
The reason I ask is my plastic cover was removed because it warped & was hitting the pulley. It was replaced with a metal cover & im thinking if the metal cover's timing marks are different then my timing would be out.
Thanks in advance
https://www.sau.com.au/forums/topic/418872-r34-gtt-detonation/
Ok so I put the car back on the dyno, the timing is set at 15 degrees btdc however it still pings right at the top of the rev range with any thing over stock boost.
In fact anything over 6psi. It appears by turbo/wastegate is stuffed as it will not hold boost. Starts at 8psi & drops to 6 but thats a different issue.
The tuner recommends I get a FMIC as im still running the factory SMIC.
Has any one had this problem before or have any idea what the problem could be?
The SMIC wouldnt be too efficient at 12psi, fit the FMIC and go from there. You need supporting mods before start winding boost up. Have a look at the rb25 turbo/dyno result thread and see everyone elses supporting mods to get an idea
  • 5 months later...
So just encase anyone finds themselves with the same issue it was the SMIC that was causing the detonation, apparently its not good for up to 200RWKW as iv read elsewhere.
FMIC fitted & no more detonation, it also gave me a 30rwhp increase.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
