  • Replies 61
Hopefully weather is like today, just came back from Syd and had lunch in Berrima and was perfect!
Saw at least 4 race cars on trailers including a lotus and an escort. I will probs go check out what's going on at Wakie after lunch before I head home.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
