  • Replies 192
my point being, the more rules there are the harder it is to judge this stuff.....especially with novice comps.
It's hard enough to judge when everyone is in one place, let alone sending in videos etc.
The simpler the better, and the more people will do it, and the more fun it will be, because these after all are only about fun.
But hey, your challenge your rules
You make a good point. Maybe the next challenge can try and embody this more.
I think Simon is right, hence why were on the second page and no one has posted a vid yet
Good challenge by the way
Note: No way of telling if someone has used chalk, plus chalk is for safety, I make sure all my clients use it.
No one really special at PTC at these, Jesse (68kg) and Bender (68kg) have done 30, Martin would be close
Nina has done 16
We always do our chins this way, if hands were turned around no one here would get 10, we all find this way much, much easier
Video is the only way we'll know! Deadlifting is one thing with no vids, but it's very easy to inadvertently cheat / screw up the form with pull ups, so vids are a must.
Will take a vid this week :)
No doubt.
I'll get a video but wanted to try it first! Its a lot harder when having to think about ensuring going all the way down, not pausing blah blah blah. Just read the rules again... "each rep is to come to a complete stop at the bottom"...hhmmmm gotta check that one....
Yeah, makes a huge difference! When I do pullups, which is rare...I do them with the pause at the bottom and I'm wrecked much quicker than on bodyweight lat pulldown, where I rarely let my arms go straight.
No. Try taking more suppliments.
lol'd
GNC Pull Up Xtend should help with this challenge...from what I read on the internet, it's designed to specifically target the lateral muscles.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
