Hey all,
Just got a V35 Coupe recently and loving it so far! One thing i have noticed with the wheels that came on the car, is that the speedo is out by 3-4km/h.
The wheels in question are:
19x10" front (245/35/19 tyres)
19x11 rear (275/30/19 tyres)
One of the rear tyres need replacing soon anyway, was just wondering what size rear tyres you would recommend to get my speedo back to normal?
Any help is much appreciated! Thanks
https://www.sau.com.au/forums/topic/419265-v35-tyre-question-my-speedo-is-out/
There's been plenty of talk on this very subject recently.
Nissan designed these cars to have optomistic speedos. With 'correct' sized wheels & tyres, the speedo will be out ~10km/h @ 100km/h (will read 110 when doing 100). If yours is out 3-4km/h then you have a larger diameter wheel/tyre combo.
It's worth noting (as previously discussed) that the ECU knows how fast you are going (with correctly sized wheels & tyres) but chooses to display the incorrect speed. This can be confirmed by an OBDII reader whilst driving.
i wish it would show the right speed then lol, it's very noticeable driving next to other cars doing the speed limit. I've confirmed it was out by using a GPS to compare the speed.
I'm thinking a larger profile on the rear may fix it? (suggestions?) :(
Edited by Murry33
Using this: http://www.exploroz....s/SizeCalc.aspx
Tyre Size Difference Comparison
Select Wheel/Tyre 1 / 240/45 R18 ** for some reason it thinks 245/45 tyres don't exist and changes it to 240/45
Select Wheel/Tyre 2 / 275/30 R19
Results for your selected Wheel/Tyre 1
Rolling Radius 338.85mm
Circumference 2129.06mm
Diameter 677.7mm
Wheel Cover Size Size 003
Results for your selected Wheel/Tyre 2
Rolling Radius 323.8mm
Circumference 2034.5mm
Diameter 647.6mm
Wheel Cover Size Size 001
Differences between Wheel/Tyre 1 & 2
Rolling Radius -15.05mm
Circumference -94.56mm
Diameter -30.1mm
When your speedo reads 100km/hr you're actually at 95.35 km/hr
Were you at the BSM cruise Murry? What colour is your new V35? I saw a heap of silver ones (and Triggs on SAU cruised with me) but couldn't find the owners of any of them (not surprising given there were over 1,000 cars!)
Yeah, but it is illegal to modify pretty much anything on a car technically ..... obviously the rim track is the big one where basically any set of rims with any sort of reasonable offset is completely illegal by the letter of the law. In SA you are allowed to increase your wheel track by like 26mm per axle legally, where my rear is 86mm wider than stock :)
Wheels
The wheel track must not be increased by more than 26 mm beyond the maximum specified by the vehicle manufacturer. Maximum allowable track measurements for individual vehicle models can be obtained from the Department of Planning, Transport and Infrastructure.
Tyres
The overall diameter of a wheel and tyre fitted to a vehicle must not be more than 15 mm greater than the largest tyre size listed on the tyre placard and not more than 15 mm less than the smallest tyre size listed on the placard.
Murry,
With the stock 18" rears (245/45R18) my speedo is almost spot-on. Your rear tyres are about 5% smaller than stock, and that's the main reason your speedo is so far out. If you went to 275/40R19 you'd still be slightly smaller (but much closer), while 275/45R19 would be slightly larger (so the speedo would probably read 1-2kph less than actual). I use the calculator at http://www.miata.net...e/tirecalc.html - you can directly compare 2 different tyre sizes.
Your fronts are also smaller than OEM, but this won't affect the speedo.
Edited by GeeDod
I think it will. Speed is determined by wheel speed sensors. Not transmission output like the old days.
You can change diff ratio without affecting the speedo.
I'm pretty sure you'll find the speed is determined by the REAR wheel sensors, so smaller fronts won't affect the reading.
This is also why a diff ratio change doesn't affect speedo reading.
Nightcrawler, yep i was at the cruise in a silver v35 :happy: your tyre comparison is pretty much spot on really
Thanks for your input guys, what other tyres could i use on the rear instead? (keeping in mind it's 11" wide lol)
Edited by Murry33
Maybe it is.. but I though the reason the staggered wheel setup on the coupe didn't impact the speedo accuracy is because the front tyre sizes are reduced by the same amount the rear tyre size is incresed, when compared to a non-staggered setup? so the average speed from all 4 wheel speed sensors is the same?
Also, the speedo doesn't 'shoot up' when you break traction on the dirt with VLSD as much as it did in my old R31.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
