Hey guys, I've just started wrecking a white series 2 R33 Skyline Gts-t here in Sydney.
It was running great before it went for a slide on a wet night and the front corner and rear quarter licked a guard rail
Chuck me a message or reply here if you're after anything - it had some dead sexy wheels and a few mods listed below:
Pickup fine in Sydney or I can send most parts anywhere in Australia
post-35556-0-62431100-1360126947_thumb.jpg post-35556-0-71167200-1360126966_thumb.jpg post-35556-0-67637500-1360128006_thumb.jpg
Aftermarket stuff:
Set of 4x Enkei AME Circlar Spec R matte black wheels and tyres - $2200 ono
Fronts are 18x9" +15 offset, rears are 18x10" +15 offset. Fits R33 gts-t without spacers and looks great, perfect for GTRs also
Tyres are Federal SS595 all round, stretched 225/40 on the front and 235/40 on the rears. Lots of tread left - 70%+
All the rims are in immaculate condition, basically no gutter scrapes to speak of at all. No stains on the silver or scratches on the black centres
post-35556-0-87489300-1360127017_thumb.jpg post-35556-0-70239200-1360127079_thumb.jpg post-35556-0-03173500-1360127091_thumb.jpg post-35556-0-08582000-1360127150_thumb.jpg
post-35556-0-55394300-1360127029_thumb.jpg post-35556-0-17191300-1360127036_thumb.jpg post-35556-0-81501700-1360127055_thumb.jpg post-35556-0-65771400-1360127063_thumb.jpg
Kics Racing Composite R40 - Wheel Nuts & lock nut set. Great condition, looked awesome on the above wheels - $100 ono
BC BR height and damper adjustable coilover set, includes C-spanners. As new condition, weren't in the car long - $900 ono
post-35556-0-96443100-1360127282_thumb.jpg post-35556-0-13133900-1360127291_thumb.jpg post-35556-0-13652600-1360127299_thumb.jpg
Hardrace adjustable front castor/tension rods. Great condition - $120 ono
Hardrace adjustable upper camber arms. Great condition - $120 ono
Nardi deep corn 350mm steering wheel + HKB bosskit (airbag/hicas compatible) & horn. $250
Immaculate condition, like new, was only used for a couple of months before the car stacked it. Have the receipt ($375 for wheel alone) and box
post-35556-0-51258800-1360127649_thumb.jpg post-35556-0-78498000-1360127684_thumb.jpg post-35556-0-70658700-1360127693_thumb.jpg
Cooling pro stealth return flow FMIC & polished piping kit, suits R33 Gts-t & R34 GT-T
Good condition, includes all pipes and hose clamps/joints. Small ding/scratch on one side, does not affect anything - $350 - pickup only
post-35556-0-41282100-1360127734_thumb.jpg post-35556-0-10750800-1360127805_thumb.jpg
Splitfire coil packs (SF-DIS-005) suits Series 1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Triple gauge cluster with smoked-face Auto Gauge gauges (boost, oil temp, water temp) Looks great lit up - $150
clips/fits right into the R33 Gts-t dash into a DIN slot. Includes all wiring, hose, water temp sensor. Second photo is with the flash on so you can see the faces
post-35556-0-35573400-1360128411_thumb.jpg post-35556-0-83920000-1360128418_thumb.jpg
Monza Oil Catch can - $40
Apexi pod filter, bolts right up to most Nissan AFM - $50
The engine has approx 120,000k's on the clock and ran great. Timing belt was replaced by Unigroup at ~94,000km in 2010
I did a compression test this week and it came up great - 150-155psi on all cylinders - chasing $1k ono for the bare engine (no turbo, coils, accessories, etc)
5 speed manual gearbox was running great as well, shifted nicely. Regularly serviced along with the engine - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc
Exterior Stuff:
headlights, front bar, reo not available
s2 front bar foglights/inducators (white) - $120 pair ono
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & rear pods - $150
boot lid & s2 spoiler, immaculate condition - $150
Engine / Engine bay stuff:
Aircon condenser - $150
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $100
Series 2 (no ignitor) Rb25det engine loom - $150
S2 afm (pink sticker) - $90
Engine Mounts - $70/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Standard fuel pump - $40
Brakes/driveline:
Front calipers, with basically brand new pads - $280
Rear calipers, with basically brand new pads - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea ono
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
S2 Front seats, great condition, small bit of wear on the driver's side in the usual area - $120 - pickup only
Complete set of S2 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 120,000km, all gauges working - $120
Instrument cluster dash surround - $100
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
  • 4 weeks later...
  • 5 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
