Hey guys, I've just started wrecking a white series 2 R33 Skyline Gts-t here in Sydney.
It was running great before it went for a slide on a wet night and the front corner and rear quarter licked a guard rail
Chuck me a message or reply here if you're after anything - it had some dead sexy wheels and a few mods listed below:
Pickup fine in Sydney or I can send most parts anywhere in Australia
post-35556-0-62431100-1360126947_thumb.jpg post-35556-0-71167200-1360126966_thumb.jpg post-35556-0-67637500-1360128006_thumb.jpg
Aftermarket stuff:
Set of 4x Enkei AME Circlar Spec R matte black wheels and tyres - $2200 ono
Fronts are 18x9" +15 offset, rears are 18x10" +15 offset. Fits R33 gts-t without spacers and looks great, perfect for GTRs also
Tyres are Federal SS595 all round, stretched 225/40 on the front and 235/40 on the rears. Lots of tread left - 70%+
All the rims are in immaculate condition, basically no gutter scrapes to speak of at all. No stains on the silver or scratches on the black centres
post-35556-0-87489300-1360127017_thumb.jpg post-35556-0-70239200-1360127079_thumb.jpg post-35556-0-03173500-1360127091_thumb.jpg post-35556-0-08582000-1360127150_thumb.jpg
post-35556-0-55394300-1360127029_thumb.jpg post-35556-0-17191300-1360127036_thumb.jpg post-35556-0-81501700-1360127055_thumb.jpg post-35556-0-65771400-1360127063_thumb.jpg
Kics Racing Composite R40 - Wheel Nuts & lock nut set. Great condition, looked awesome on the above wheels - $100 ono
BC BR height and damper adjustable coilover set, includes C-spanners. As new condition, weren't in the car long - $900 ono
post-35556-0-96443100-1360127282_thumb.jpg post-35556-0-13133900-1360127291_thumb.jpg post-35556-0-13652600-1360127299_thumb.jpg
Hardrace adjustable front castor/tension rods. Great condition - $120 ono
Hardrace adjustable upper camber arms. Great condition - $120 ono
Nardi deep corn 350mm steering wheel + HKB bosskit (airbag/hicas compatible) & horn. $250
Immaculate condition, like new, was only used for a couple of months before the car stacked it. Have the receipt ($375 for wheel alone) and box
post-35556-0-51258800-1360127649_thumb.jpg post-35556-0-78498000-1360127684_thumb.jpg post-35556-0-70658700-1360127693_thumb.jpg
Cooling pro stealth return flow FMIC & polished piping kit, suits R33 Gts-t & R34 GT-T
Good condition, includes all pipes and hose clamps/joints. Small ding/scratch on one side, does not affect anything - $350 - pickup only
post-35556-0-41282100-1360127734_thumb.jpg post-35556-0-10750800-1360127805_thumb.jpg
Splitfire coil packs (SF-DIS-005) suits Series 1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Triple gauge cluster with smoked-face Auto Gauge gauges (boost, oil temp, water temp) Looks great lit up - $150
clips/fits right into the R33 Gts-t dash into a DIN slot. Includes all wiring, hose, water temp sensor. Second photo is with the flash on so you can see the faces
post-35556-0-35573400-1360128411_thumb.jpg post-35556-0-83920000-1360128418_thumb.jpg
Monza Oil Catch can - $40
Apexi pod filter, bolts right up to most Nissan AFM - $50
The engine has approx 120,000k's on the clock and ran great. Timing belt was replaced by Unigroup at ~94,000km in 2010
I did a compression test this week and it came up great - 150-155psi on all cylinders - chasing $1k ono for the bare engine (no turbo, coils, accessories, etc)
5 speed manual gearbox was running great as well, shifted nicely. Regularly serviced along with the engine - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc
Exterior Stuff:
headlights, front bar, reo not available
s2 front bar foglights/inducators (white) - $120 pair ono
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & rear pods - $150
boot lid & s2 spoiler, immaculate condition - $150
Engine / Engine bay stuff:
Aircon condenser - $150
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $100
Series 2 (no ignitor) Rb25det engine loom - $150
S2 afm (pink sticker) - $90
Engine Mounts - $70/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Standard fuel pump - $40
Brakes/driveline:
Front calipers, with basically brand new pads - $280
Rear calipers, with basically brand new pads - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea ono
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
S2 Front seats, great condition, small bit of wear on the driver's side in the usual area - $120 - pickup only
Complete set of S2 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 120,000km, all gauges working - $120
Instrument cluster dash surround - $100
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
  • 4 weeks later...
  • 5 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
