Hey guys,
I’ve heard of these tuners on the net that you apparently can send in the list of mods you have done and they tune it as best as they can. Then you go get a dyno run and check your mixtures and if they are not 100% you can send it back and they will adjust it for free.
The reason for me looking into this is its $200 and I’m trying to do up my r33 gtst as cheap as i can as i have a young family and I don’t have the luxury to spend thousands on my toy so its a slow cheap project.
I’m not planning for it to be to crazy I’m hoping to have a r34 side mount water cooled and 3 inch full system fuel pump standard air box with k&n panel
Has anyone had experience with these internet tuners what’s everyone opinion?
https://www.sau.com.au/forums/topic/419571-internet-tune/
$200 fora R33... Sounds very wrong.
As above, if budget - 10psi is fine (12 can trip it out).
Nothing will beat a proper tune and 'mailorder' tunes will not be much better than a stock ECU as you have to be so conservative.
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6743266
Normal tune $600-1500 depending on workshop.
Tunable ECU is between the same $500-4000 depending on brand.
Decent power depends on what you think is decent and again how much you can budget into it.
Reliable power and low budget do not mix at all sorry to say
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744438
ok so if i was to do
full 3 inch system
fuel pump
k&n pannel
water coolded r34 intercooler
10 psi
maybe a tune later on down the track
that would be ok power? there is nothing else i could do on the cheap
and for those mods what kind of fuel pump do i get? and would you bother with injectors?
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744577
With a budget build I wouldn't bother with injectors because they will require a tune
The stuff you have listed will be fine without a tune as long as you make sure it's 10psi and no more.
With a tune it would make a huge difference though.
I went a walbro 255 as they are easy to fit and no expensive. Got mine for $200 including the install
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744622
full 3 inch system
fuel pump
k&n pannel
10 psi
34 coolers are water to air?
at the power levels youve hinted to being able to afford right now, keep the standard cooler.
again, dont worry about fuel pump either.
just get a boost controller(electronic) and run 10psi, the factory systems should have enough leway in them.
start saving, and do a nice group of mods when you can afford it.
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6745377
Hey guys,
Hey mate
Best thing to do is contact Toshi
He is on SAU and is fantastic
Costs about $400
He will send you replacement ECU that he has socketed and rechipped for your mods
Very very accurate tune
He has done many tuned chips for so many different configurations of mods
My car is an R33 GTST running 12PSI and has FMIC and 3" with man boost control
I beat most V8's out there and air fuel ratios are spot on
Also great MPG.
If you need any help contacting him just ask
And for all you doubters out there I say come for a drive of my car (or a race!!)
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6746062
Hey mate
Costs about $400
Also great MPG.
Good read, would lol again
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6747124
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
