  • 2 months later...
  • Replies 75
Posted Images
going for my tune very soon so i need some tips and advice.
i have my gt30 on my manifold with external gate welded off it. Runs ok but stalls if i hit boost then back off, it does no stall if i down gear.
any one else had this trouble ?
do i keep my airflow meter in the stock position ?
and the injectors im looking at buying are bosch1000cc. if they are 14mm top 48mm in length and 14mm bottom they should drop straight in to the standard r34 fuel rail true or false ?
You have a GT30 externally gated and haven't tuned the car yet?
Sounds like afm reversion, can you post pics of the intake setup?
I would love to help you out with the injectors but the guy supplying them should be doing that, surely.
ive had that problem of the stalling so will be interested to hear if you fix it, once you get it tuned you'll be loving it, nothing like an angry rb and E85 is a must :P
also talk to injectorsonline, they'll help you... another great supplier
Edited by AngryRB
Can I test if its the bov if I disconnect it? Or does it have to plum backed though the standard pipe
Needs to be plumb back, flutter is still going to cause issues with air flow.
I think the issue will be with reversion though. That AFM is too close to the turbo there, and your intake pipe only has one bend in it. An 'S' shape would be better, and the AFM should be a bit further away from the turbo. Really you should be extending that intake pipe anyway, you've got that pod filter sitting right in the hottest part of the engine bay.
My plan is to reuse the standard air box. The pod set up is just temporary. I want it to be clean and easy for my tuner to work with, and the more stock looking the better.
Best to fix the reversion issue before giving it to the tuner. Shouldn't be too hard to setup so that it can still be temporary, that intake clearly isn't going to work with the standard air box as it is anyway. I would suggest welding another 90 degree bend onto that intake pipe, one that positions the intake so that it can still work with the standard air box. Or at the very least, buy a 90 degree silicon joiner and use that for now.
With any luck, that will position the AFM far enough away from the turbo, and the two bends in the intake pipe should help prevent any reversion as well.
You should never tune teh car with one type of filter on it (pod) and then change to another sort (airbox). The airflow pattern into the AFM will differ between the two giving slightly different signals for the same quantity of air (or the other way of looking at it, at the same AFM signal you'll have a different amount of air flowing). This is of course completely mental. The only way to do it is to keep the same filter setup.
When I first turn on the car it idles and runs fine. But let's just say if I go shopping and come back after 30 mins the car runs really bad. It seems like if the car is flooding or the plugs are fouling up !
Any ideas? it's just started last night !
Change the plugs about 3weeks ago
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
