Last night before major surgery fingers crossed please guys and maybe some prayers if possible, thanks for all your support thus far I'm pretty sure I will be ok but depends on gods plan
Will do mate.
Catch you on SAU in a few days :)
Amen to the Prayers! I can't even imagine what you are going through. My thoughts and prayers will be with you also.
Life is a precious gift.
When you have had your operation, and put this behind you, you will appreciate life more than you ever did!
Too many of us take what we have for granted.
Good things come to people who live life with the attitude of gratitude.
I wish you and your family&friends peace and strength on the day, and a speedy recovery.
I echo David in prayers for tomorrow Scott.
I guess u can't email something that big?
Nope, afraid not. PM me your address and I'll clear a portable HD, fill it with stuff and mail it to you. Just return it when you're done.
Good Luck! We're all pulling for you here.
Good luck mate! I really really hope that all of this plays out in the best case scenario, and you make a quick recovery, and back doing skids in no time.
Positive mindset at all times my friend!
Cheers,
Shazza
Edited by XS80ST
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
