What Type Of Turbo Do You Have In Your Stagea?
Brotato
 Share
Searched the topics, nothing came up but just wondering what type of turbo do you have in your car? Stock? Thinking about getting a new turbo for car, also wondering what the standard turbo comes with the series 2 stagea?
Many thanks for your time,
Happy lunar new year to you all :)
Standard turbo on the stagea series 2 is the R34 Neo turbo which is slightly bigger than the r33 turbo. It has the OP6 rear housing which is bigger then that of the r33 turbo. The easiest route to go down is to get your standard turbo highflowed by GCG or Hypergear. That way all the standard lines remain the same and it bolts up just the same as a standard turbo and the internals of the turbo are bigger and you get steel wheels which can hold more boost safely. Stock turbo is only good up until around 12psi. Any more and it will get too hot and potentially shagg out.
Do some searching - there are heaps of threads on this. Best bang for buck something like Hypergear. If you get a big enough turbo you are going to need thousands of $$$ supporting gear and then better brakes, suspension etc.
Yep, M35.
Turbo's fail from oil supply issues and heat/tune issues. Which one caused yours to blow Damo? Blaming GCG won't help anyone, if they had done a poor job you would have known about it in the first week.
GCG seem to have a bit of a rep for building incredibly noisy BB core turbos, and then showing very little interest when customers start asking questions.
I spoke with them when looking around for a supplier for my highflow, I was not impressed at all. Super vague; they just wanted me to throw money at them, stop asking questions and get off the phone.
A friend who is building a massive dollar 351 XB Falcon TT engine for his ex Street Machine cover car was prepared to spend $10000+ for the right turbos, manifolds & supporting parts; they wouldn't even give him the time of day.
I don't understand them at all.
John at Precision Turbochargers (Wetherill Park) spoke to me for over an hour on the phone; then invited me to his workshop for an extended chat and actually showed me a M35 turbo that he was building. He then told me what he wished the customer would let him build then asked if he could build it for me.
I agreed and he was awesome.
I rang him after I had run the 13.8 at EC; told him, and he was absolutely over the moon! He was stoked that I'd taken the time to ring him back, but was really happy that his opinion on the specs of the turbo had turned out to be right.
I agree, but very few turbo builders will show interest once the turbo is shot. John and Stao are the only ones it seems that are genuinely interested and willing to go out of their way for the customer.
After seeing the crap built up in some of these engines, I can imagine the ease of which a small piece of crud could enter the restrictor and limit oil to the core. (which is why I used a small inline oil filter on my Garrett.) Most noisy turbo's would be caused by this lack of oil imo, only ball bearing cores are susceptible as bush ones require larger flows (bigger/no restrictor, more chance of the crud making it through the turbo.)
Bang on Scotty, most honest turbo builders acknowledge that if you're putting a brand new BB core on an old engine; it can very easily fail due to oil contamination.
Given the access issues with our set up; where do you have the filter? Is it straight out of the feed port on the block?
I have an open banjo on the block with a 3an fitting into braided teflon hose, the filter is then inline before 2 x 90 degree bends into the turbo, no restrictors as Garrett turbo's usually have a perfectly sized restrictor built in.
I can't get to it, but I don't seem to have to, it was clean when I swapped to the GTX3076 from the 71.
ATS Adelaide turbo services highflowed mine.
Stock nissan V45 front compressor housing, ported out to the max.
Garrett gt30 ball bearing core, internal wastegate
Avo .73ar skyline exhaust housing
Very happy with it. Owned for a few years now too. Was nice at 250kw at 16psi with leaking rings, now forged motor but not power tuned yet. Expecting at least +270kw on around 18psi.
 Share
    • And yes would be going to tomei Japan for sure as it’s closer to me …
    • Yeah I heard the same. Might be hard to order one. But then I guess can go to hks or go to a more expensive n1 block with tomei. Guess will jump the hurdle once I get there next upgrade around. I can’t get work done in the states as the lead time will take for ever on top of shipping to Hong Kong.
    • https://www.platinumracingproducts.com/en-us/products/nissan-rb26-cast-blocks This is the solution I was thinking of. I would stay away from Tomei USA, their quality is a question mark to me. If you want an engine machined in the US contact Club DSPORT: https://clubdsport.com/ Tomei JP is probably fine but I recall they stopped doing pre-assembled short or long blocks. In general it's pretty tough to get any kind of RB26 block at the moment with Nissan so severely backordered.
    • PAR specifically offers stock ratios in their gearset and you could do whatever ratios are physically possible supposedly for no extra cost. I agree 6 ratios is better than 5, the factory 2nd gear is equivalent to the Getrag 2nd gear if you account for the differing final drive ratio though. The Getrag 3rd gear with a 3.916 final drive is equivalent to a 1.6 2nd gear in the FS5R30A. I'm about to swap the transmission out on my car, I'm tempted to send the one I have now out for rebuild with the standard "cross ratio" gearsets out there to see if it really makes such a big difference the next time I pull the transmission.
    • This is what I was looking at next:  https://www.z1motorsports.com/engines/tomei/tomei-rb26-28l-short-block-assemblies-p-45479.html as we can’t bore the cylinders out in hk so better just buy the whole lot in one and install then retune. Everyone saying the weak link are the bolts holding the rods together. I already did valve springs, arp head bolts, hks racing coils, nismo fuel pumps and pressure regulators, injectors etc for the top of the engine.
