  • Replies 65
I remember fapping over the orginial deus ex back in school, but am yet to play any sequels. Generally sequels frustrate me but sometimes they are better, much like movies bar a select few. Have also heard big things about the mass effects but not motivated to play them having never played any in the series. I guess I am at the stage where if I dedicate time to a game it would want to be worth it! Pretty much havent been obsessed with a game since Skyrim
Good thing about HR is that it isnt a sequel to the first or second games
It is set a couple of decades before the first one so story wise it is unrelated to the first, and being made 10 years later, its a new engine, new artwork etc
Oh also Chivalry: Medieval warfare is good fun for the lulz.
This, am enjoying chivalry, still needs a bit of balancing though
Can you fags add me on steam so I dont play chivalry on my own...
jackinthebox222
lol so getting this game, hit boxes look pretty dodge but the gore makes up for it.
Anyone know much about the new CS that's out/coming out?
Wouldn't mind knowing about the new CS as well.
Had a game on source after many years of not playing and loved it!
Hitboxes in chivalry are pretty hard to get used to.
Archers also suck!
Still a great game for a few hours of fun
The new CS is pretty much HD old school. In terms of a game it will not be brilliant. However its CS so who gives a sht.
Daniel add me you fag. Anfanee. Same name on EVERYYYYYTHING. LoL, Steam, XBL (though i never use my sexbox)
Terraria, Minecraft, ArmA 2 (Day Z and Wasteland), Baldur's Gate, Knights of the Old Republic or Chivalry.
All fairly cheap and excellent games available on Steam (Minecraft isn't, but its still excellent).
Skyrim and Borderlands 2 are games I have sunk a boatload of time into. Not a lot else otherwise although I am just starting up Dust 514 (I know, PS3 only. Whatever).
If you wind recent games boring/samey why not pick up a SNES with a disc drive (Game Doctor SF3). Can't go wrong with the SNES classics :)
Funny you should mention that, I was actually trying to find my old emulator/roms the other day :P Seem to have been lost with the new build though...
I read/heard Aliens CM is a major disapointment so I'll probably just torrent it, in the meantime I loaded up MAME again to play some old 90s arcade games to relieve the memories I never had since my grandparents won't let me have any money.
Best place/way to buy BF3?
After watching the yt vid on the first page I had to go watch Aliens :P
And to contribute to the thread I highly recommend anyone who hasn't played Bioshock check it out. Dead Island was a big surprise for me too for a hack and slash shooter
Hmmm BF3
Try get a premium edition straight off the bat because that aces the hassle of all the map packs etc
Check the price through the origin platform
If not then maybe a few of those pc cd keys online sites. They are really cheap
g2play.net for BF3 Premium. It's where i get pretty much anything that isn't on Steam.
So $59 for the Premium and $42 for the extra DLC - and there is HEAAAAAPS of play time.
Wish i had time for gaming atm lol, been 2-3 months since ive even fired up a game.
^^^^ +1
Also the upcoming South Park and the Stick of Truth looks pretty good - if you like the show you will like this....although ETA is sometime this year some say june some say december :(
Edited by milanr34
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
