  • Replies 57
I'm out. Extremely sore
went gym now im exhausted, sorry guys =[
Sorry I didn't make it to this one I was a bit tired after gym.
Thanks for the trophy from the 2012 show n shine :)
Hopefully ill make the next meeting.
Do you all, even lift? LOL!
Awesome photos Jamie!
Was a great night, congratulations to those that won an award. See you all next time! :D
My inferior photos haha
Haha! Thanks!
All good man!
Hey I stopped being a pussy and still came along.
I'm trying to lift lol
Yeah, at least you came down... LOL!
Missed again, our daughter had her first child Wed night :-) and i had to adjust my priorities.
So I guess I should change my nickname to gramps :-/ maybe get an evo 7 gt-a.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
