Looking at fitting harnesses in my stag as when cornering at speed you have to brace yourself a bit at the moment. Anyone else fitted harnesses? Wanting to keep it practical with useable back seats so was thinking either a double release harness. Original plan was to put a harness mounting bar behind the front seats but not found any for stageas.
https://www.sau.com.au/forums/topic/419782-racing-harnesses/
Yep I fitted a couple of Recaros from a Euro Honda or something - more comfortable than a race seat for my daily driver but heaps more control on the track. In this country (don't know about UK) if you fit a harness you have to be a member of a car club, run a log book etc.
Yeah reclining are ok. It's to do with cutting people out of cars. Harnesses have to have a red release button so can easily by identified and seats must recline so they can get you out on a spinal board. It's meant to come into affect in April, they tried about a year ago but realized none of the mot garages were prepared.
As much as it pains me; that's actually a very smart policy.
At least there's logical reasoning at play in the decision making process; rather than the usual "Don't do it or we'll fine you" mentality we have in Australia...
Providing you have a WC34 Stagea a relativly cheap and good looking option is a pair of front seats out of a R32/R33/R34 GT-R. I believe they bolt straight up!
Personally I wouldn't be using a harness on the street anyway. While you are strapped in you can't move your body to look around properly (ie checking blind spots while merging lanes and parking)
  • 1 year later...
Honestly I found I could corner much faster while held in with a decent seat - I have used an aftermarket bucket seat and also a Recaro from a Euro Honda and both gave excellent results. I suspect a GTR seat would be also be ok and would have the advantage of bolting straight in to the existing holes without the need for an aftermarket seat base and slider.. As part of my cert process I had to fit seat belt anchors to the transmission tunnel so pretty secure as well.
You do realize that the back seats have to be removed and the belts must go back as straight as possible so as when you go over you body weight doesn`t go on your shoulders >back , Cams stipulation read the regs also road authority.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
