I can't make it this year, but I am dead keen to get there one year. Good luck Tom
Anthony, they block off a section of the old lakes way near bulahdelah. A bit like the old pac highway, an absolute blast to drive with no speed limits :)
sounds good.
will have to try one year.
ah yea i drove that bit of road recently.. its good fun.
Cheers.
The Bulahdelah hillclimb is organised twice yearly on the challenging hill of the Bulahdelah Mountain crossing of the old Pacific Highway. Now bypassed by the modern highway, the course is set in pristine bush land and just to be there for the day is a relaxing family experience. Throw in the excitement of the climb and you have a great day.
Newcomers welcome! Participating in this event qualifies you for a full competition licence for 12 months at the very much reduced rate of $50.00!
Qualified official? We need you on the day, please join us in the day's fun.
For entry and supplementary regulation details, visit our web site on
e-mail enquiries are welcome on
Entry $120.00
For visitors to our area, accommodation of your choice can be selected at the following web sites:
www.tripadvisor.com.au
  • 3 weeks later...
Cancellation of Hillclimb Event March 2013
We regret that we have had no option but to cancel the March Hillclimb. This has been due to there having been insufficient entries. We have noted that at this time of the year, several other events are on offer so we attract a few less competitors.
There may be a few who would want to turn up on the day, but we cannot plan for this, the costs of staging the event, unless covered by entry fees would see us unable to continue in the longer term.
So we hope to see you at our next event, which we believe at present will be held on September 22nd 2013.
0408 290 286 OR 0403 748 629
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
