The power figure is just a number, Mark. It's how/where the thing delivers that this thing should show its worth.
A slightly smaller, earlier spooling unit (vs the well regarded 3076) really should be making the most of things lower in the rev range and putting distance on the bigger units before they get a full head of steam. You'd expect that they are going to blow by in the higher revs.
It would be good for Mafia to comment here, but I do believe the 0.63 IW housing did experience difficulty with boost control and was only happy above 18psi. BHDave also struck similar issues with his 3071. I'd suggest your builder might be looking to avoid that, but reckon this unit may not pose the same problems if so configured.
Either way if this 0.82 setup ended up making 16-18psi by around 3200rpm and the engine continued to make torque up to 7000 without falling over, you'll be on a good thing. 250 is only a number, and if it made 260 on pump 98 I'd think you've got a winner.
Adrian I've driven both 0.63 and 0.82 and 0.87 Pro S equipped GT30 setups. And I've provided comment about relative performances.
Characteristics aren't radically different. Basically the smaller housing provides higher gas speeds earlier, and at least with Mafia's setup also became restrictive earlier so it stopped making torque in the higher rpm range (ie power peaked sooner than the 0.8 sized housing).
The on boost torque curve effectively shifts to the left by 500-750rpm dependent on pipework, attention to smooth transitions, and whether it's on alcohol or water injection. Your 52T 3076 if/when tuned should be on full song from somewhere between 3800-4200 so that should tell you when Mafia's became lively.
For reference purposes - boost graph of a 52T 3076 on an SR with twin scroll .78 hsg. Note that 150kpa is a tad over 21psi - which as you can see is made at around 3750rpm and positive pressure at approx 2300rpm with big Hypertune short runner plenum. At the end of the tune it went on to make 389hhp on BP98 with 240hhp at 4000rpm. Very torquey (for an SR20) and revvy setup. I changed over from a GT3071 on the same setup but with larger dump 3.5 inch up from 3 inch and the 52T 3076 is superior in every way.
I expect it would work equally as well (if not better) on an RB with .5 litre larger capacity in a single scroll format with standard intake manifolding.
Edited by juggernaut1
Judging by the thread responses this thread is about a 3067 vs other Garrett variants. I'm only offering my experiences so people can make an informed decision about turbo choice.
You're absolutely correct of course Dale. I'd be very surprised if I could even tell the difference between 250 or 260 kw driving it. Still, I did set a target for what I was chasing. :)
Time will tell , if the turbine response is adequate then the larger housing will pay off in other areas .
One is exhaust heat and pressure which often leads to detonation . You would think that with a less detonation tolerant fuel like P98 a bit more boost and and a bit less exhaust restriction will make more power .
Assuming the tuners do a good job with the light load low end areas the "torque crossover" of engine only to boosted performance should be acceptable .
Updates for one of ye olde GTX variants.
Some may be interested to know Guilt-toy is back and doing his thing. I saw him today to retune my car for the new setup and am over the moon with the result. I have never met a more approachable and reasonable tuner, and the result speaks for itself. I have driven my car extensively over the last decade (previously owned by a friend) and have driven it from stock and various levels of modded states.
The current setup is as follows:
Forged SR20 (not ported, not anything, just forged)
256 Poncams (non VCT)
GTX3071R
MX performance T3 manifold
38mm gate
Nistune, FiveO 850s, Z32
Homebrew dump and all intake plumbing
Results as follows:
https://scontent-a-sjc.xx.fbcdn.net/hphotos-xap1/t1.0-9/10492077_10152228519029211_1017884650130421043_n.jpg
https://scontent-a-sjc.xx.fbcdn.net/hphotos-xpf1/l/t1.0-9/10485661_10152228519059211_2427511659465411306_n.jpg
GTX3071R
38mm gate
Results as follows:
Congrats, again sir :D That has to be a fun drive :)
Seeing as GTScoTT hasn't responded yet, I happen to know it's on 98 - get it drunk, boy.
Mr Lith has it covered. Just chilling on 98 for the moment, at least until its a little more readily available.
Am very happy with it. I was a little tired last night and didn't quite finish what I was trying to say:
I have driven my car extensively over the last decade (previously owned by a friend) and have driven it from stock and various levels of modded states. The car has never been this good. It is way more responsive than I'd ever imagined it would be and so far has given no shortage of awe for anyone that has passengered. Most friends specifically comment to say that it feels like any other turbo car until you give it a boot full. It honestly was not this smooth or potent when it was stock.
Nice :D Glad someone has had good results, even though it's not really what the thread is about - here's hoping m@&k's luck changes, seems like another "pick up date" has come and gone past like the wind :(
To be fair, I think it's a very effective setup but I'm not sure when I missed an engine with upgraded internals (including cams), aftermarket exhaust manifold/wastegate etc running 22+psi became mild!!! :D But yes, that thing is clearly going to be a weapon.
Results look great Scott. What engine speed does 100kph correspond to on the Silvia? Around 3,800? Was impressed with how quickly it built boost in the vid you posted as well.
Yes Lith, pick up date has slipped again, but looks like only by a day. Received a quick email late last night saying it had come back from the tuner yesterday afternoon. In Josh's words: "drove it this afternoon, really loving how the power is coming on". They're giving it a check over today to make sure it's ready for pick up. I'm hoping to be able to get it after work today.
Your confused with stock-ish ;)
@ Mark - here was my previous GT3071 setup revved to 8,000rpm so 4,000rpm would be around 112klms
Cheers, I wasn't too far off then. Looks like Scott's GTX3071 has similar boost threshold / spool characteristics as the GT3071? Although I guess not really comparable on different engines...
Edit: I realise they're both SR20s, just they've been built differenty.
Awesome - sounds promising, have you got a number yet... or are you wanting to check it all out before you report? :) Either way, glad it's done finally!
No numbers as yet. Might have to wait until I pick it up. Unfortunately, it's pissing down rain here today. Won't be able to go for a decent drive for a couple of days probably...
Edited by M@&k
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
