ive been playing with my 98 GTT a bit lately... new 3" turbo back and a couple of other replacement items.
ive just scored a stock XR6T front mount for the right price ($0 to be exact) and wodered if it would provide any gains over the standard item?
it will be a no cost mod as i have plenty of pipes and joiners at work, but ultimately would it be worth fitting up???
any advice is appreciated.
thanks in advance
Matt
if you are running stock boost and stock turbo then the gain would be minimal IMO.
Also if you plan on mounting it in the factory location i think you might find it worse as the airflow is directed to the stock cooler via shielding etc
happy to be corrected but i dont see it being a worth while 'upgrade', the stock cooler is good for 10-12psi for road use, track is different story
Are XR6T FMIC's return flow?
You'll have to get custom piping made up for it... and work out a way to mount it...
Probably better off getting a JJR Cooling Pro FMIC which you know will fit perfectly.
If it's a BA/BF cooler it's return flow. FG's are similar to a Gtr cooler but narrower and almost twice as tall.
If the car is fairly standard the the BA cooler might be worth it but if you plan on running more than 12psi then you need something decent.
yes its return flow
id look at mounting it up front.
as i said pipe work is no issue as i have access to a pipe bender and plenty of rubber/silicone couplings.
i do have a new turbo sitting at home for the baby ( not sure of exact specs) that came of a mates r33.
ive got new coils on the way.
i will be upgrading computer and injectors in the near future.
it was the right price so i considered putting it in since im a tight arse and would rather spend money on a computer so i can run the new turbo...
Waste of time.
The BA/BF return flow cooler will heatsoak at 240rwkw as noted. The massive FG cooler will do the same thing at about 300kw, so neither of which are worthy options.
Better off with an off the shelf cross flow china kit.
China kit - easier to install, waste less time making piping, comes with brackets will perform better
DIY kit - headache, waste more money overall once done, won't sit nice and will perform crap like others have mentioned
Should weigh it out, ling long kit will be better in terms of fitment, cost effectiveness and performance
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
