Sau Qld Blood Drive - 04Th May
Just did a quick head count and it seems we only have 20 people confirmed. Come on boys, pony up!
THERE will be ladies! There will be food! There will be lollies! And there will be prizes!!
  • Replies 97
Time slots allocated to us if people could book in advance that'd be great.
I just need your name and whether you've donated before.
10am Hivefleetabyss (Zeke)
10.15 Mrs Hivefleeyabyss (Becky)
10.30 Cadmoon (Michael) and
10.45 V8skylineman and
11.15 Cowdy & Mrs Cowdy (Zac & Kathryn)
11.30 T5IV (Tony) and
11.45 x 2
12.00 Miss-R34 (Chantalle)
12.15x 2
12.30
12.45
1.45
2.15
2.45x 2
3.15 x3
12:30 for me thanks.
11.45 x 2
12.15x 2
12.30
12.45
1.45
2.15
2.45x 2
3.15 x3
12:30 for me thanks - will only be me - Have not donated before
Thanks Ants :)
Just to pull at your heart strings a little.
There was a little 14 week old boy from the Goldie named Ryven Harris featured on 'The Today Show' recently. Ryven has a very rare blood condition where he doesn't make platelets (the bits used for clotting) and to make matters worse he is O- (the rare one). As O blood types can't take any other types they had to find a donor with O- blood.
O+ blood (such as myself and about 50% of the community) can give blood to anyone but can only receive other O+ blood, if we don't know someone's blood type and we have to give blood products we automatically go O which means its the first to run out.
Here is a link to the YouTube clip: http://m.youtube.com/#/watch?v=A9oq1inN940...v%3DA9oq1inN940
11.45 x 2
12.15x 2
12.30 Ants (Anthony)
12.45
1.45
2.15
2.45x 2
3.15 x3
Can do 10am. :)
Are you able to do 10.30? Zeke and Becky have called dibs on 10 and 10.15. You can laugh at Michael.
Either very early or very late for me x 2 please
2.45 sound good Mike?
Thanks Ants :)
Thanks Chantalle,
I know its for a good cause + will be good finally catch up and greet some fellow members.
Kind of nervous and excited at the same time though :blush:
Edited by Ants
Thanks Chantalle,
Glad to hear it mate!
Look forward to meeting you and hopefully seeing the GT-R
Unfortunately I highly doubt that the GT-R will be ready in time for this weekend Tony :ermm:
I will contact Gavin Wood and see how he is progressing with it (haven't heard from him for two weeks now)
May just have to be for another time where I can show off all of its glory :D
10.30 Cadmoon (Michael) and Reserved for SABBAi
11.30 T5IV (Tony) and Matt P (Cowdy's friend)
11.45 x 2 Grae35 & Mrs Grae35 (Lyn)
12.15 Boiracer & Mrs Boiracer
12.30 Ant (Anthony)
12.45
1.45
2.15
2.45x 2 Anna & Bunta
3.15 x3 Reserved for Magic Mike & Mrs Magic Mike
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
