Import Monster Sauvic Deca Motorkhana - 16Th March 2013 - Entries Open
  • Replies 139
Doh, I'm out, car will not be back till next week so insufficient time to bed in the new clutch. Email withdrawal request sent.
Peeved, old tyres have to come off so this was going to be a perfect opportunity to send them out with a bang!
Pfft. I put a clutch in my car the thursday night before deca. Pretty easy to bed a clutch in on a 200k drive to Shep!
Hi Rob,
It'll arrive in a few days and be posted up in here...
They'll also be available in printed form on the day
There's not a lot you'll be able to pre-study for them, it'll need to be studied on the day when you can see the layout in front of you :)
Its being uploaded today hopefully.
Looking forward to this one, the sil80 is back! And there is no way im painting it orange btw, Leon has enough wannabes ;p
Who is staying at the Sherbourne and is trailering their car up?? Make sure you can lock your trailer to your car good and proper. Getting mixed reports on where we can and cannot park them.
Orange is for menage en trios drift cars...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
