I’m stripping the donor car that I just purchased. It has 150K on the clock. It doesn’t run, so parts are as is and I think the prices should reflect this.
Note: I’m keeping the engine and a few ancillaries. I’ve listed what I’ve removed from the car so far. The rest is up for grabs, but it will take some time to remove the remaining parts.
Location and conditions: Prefer pickup for larger items, but shipping can be arranged a buyer’s cost.
I’m in Kinglake and can bring to work with me at Mulgrave if you want to collect during the day.
Contact: Jack on 0401994746, or PM me
Item: Standard exhaust from dump rearwards with canon muffler attached
Condition: Few scratches, but seems in OK condition - meh, it’s an exhaust!
Price: $80
Item: Standard radiator with shroud. Has oil transmission in/out bungs
Condition: Second hand, Fins look OK, it has a few dings as you would expect. Looks OK to me. As is.
Price: $80
Item: AC condenser, compressor, cannister and piping
Condition: Second hand, as is
Price: $80
Item: Standard intercooler with shroud, mounts, all hoses, clamps, piping
Condition: Pretty good nick, I reckon.
Price: $100
Item: Auto diff & cross member with Hicas attached
Condition: Hasn’t been run up, so I can’t vouch for its operation
Price: $100
Item: Front bumper
Condition: Gun metal grey, definitely needs a sand/spray
Price: $90
Item: Rear bumper with side pods
Condition: Maroon (wine red?), will need a spray
Price: $90
Item: Bonnet
Condition: Silver, previous owner sanded it and left it that way – so will need painting
Price: $50
Item: Spoiler
Condition: Maroon (wine red?), looks OK
Price: $50
Item: Left and right electric mirrors
Condition: White – looks unpainted. Can’t test them, but look in newish condition
Price: $100
Item: Standard intake hose with piping attached
Condition: Looks in good condition
Price: $80
Item: Set of genuine Skyline mats, including the transmission tunnel mat
Condition: Used, but scrub up OK
Price: $100
Item: Pair of tail lights
Condition: Maroon (wine red?), average condition
Price: $50
Item: Pair of S1 head lights
Condition: Average condition & a bit hazy, but can be polished up as per the countless threads on how to restore headlights
Price: $90
https://www.sau.com.au/forums/topic/420596-stripping-r33-gtst-s1-auto-in-vic/
Do you have the passenger side inner guard lining? The front piece. Although both sides would be handy. Also do you have the under engine tray?
I assume you mean the front passenger inner guard lining? and the engine tray between the radiator and engine? Then yes I do. The drivers side inner lining is stuffed though.
has the box had any work done mate? also.. how much for afm and ecu?
dunno whether the box has had any work. Haven't pulled it out yet.
AFM and ECU pricing in a PM to you.
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
