a few of us just did a wedding for one of the main guys that run SAU, some beautiful cars are available man
mine was one of them, nek minnit, started spraying raw fuel everywhere and i had to bail
but that wont happen again lol
https://www.sau.com.au/forums/topic/420627-wedding-cars/#findComment-6765969
At least it would have been putting on a show at the wedding :P Flame thrower style ;)
haha yeh imagine spraying everyone with e85
at least it smells sweet haha =\
you let us know what colours/styles/bodykits etc
im sure 99% of us will say yes for a tank of fuel
https://www.sau.com.au/forums/topic/420627-wedding-cars/#findComment-6766893
LOL heard about this wedding, didn't know you went.......... ye im down too if you dont mind your guests leaving deaf and possibly burnt by exhaust flames..........inbox me if you want. I have a Nismo sorted bayside blue v spec II :)
https://www.sau.com.au/forums/topic/420627-wedding-cars/#findComment-6767629
  • 11 months later...
Haha I'm just joking bro, you'll have to read some other threads to get it :P.
I'm sure someone will put their hand up to give you a hand. Sadly don't own a 34R so can't help; hope it's a great day though mate (Y)!
https://www.sau.com.au/forums/topic/420627-wedding-cars/#findComment-7188479
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
