Ok car was goin perfect but yesterday morning it suddenly had like no power when i accelerated, it would do the turbo wind up and all but just no power, later the car went weird wouldnt rev past 3.5 rpm, smoke coming out exhaust, hunting idle, misfiring. I replaced spark plugs, tested coils (splitfires), check aac valve, check for vacuum leaks checked maf, checked intercooler.. Things done before prob i adjusted boost and put 20 dollars prem fuel in car.... Please help im seriously stumped car has fc commander, splitfire coils, stock bov, pod filter etc. 1994 r33 manuel
Edited by Nige1
I'm having the same sort of problem, car won't idle, misfires, heaps of black smoke. I haven't even tried to drive it, won't hold revs. The day before i took the coil packs out and taped them up, to fix a miss at boost, which it did fix. gave it a bit of a hiding and the next day it wouldn't run. just put a brand new set of yellow jackets in there, changed plugged, can't find any cooler leaks or vaccuum leaks. cleaned the maf
just about ready to try get it towed to a mechanic
I know what you mean, mine drives rough when it hits 3.5 rpm it starts misfiring hard and revving out and the idles fine until i rev it then it goes to stall but regains it self idles shit for a few seconds thn kinda goes bak to alright but not fully
have you checked it....im assuming a Z32? from what your saying it seems like it could be playing up causing your car to over fuel (at a guess). Start there! try cleaning it. Try disconnecting it when the car is idling there will be tell tale signs. If you have a spare or know someone try replacing it...
Me and mate have narrowed it to either afm, bad petrol or the fc commander.... Does this sound possible??
my guess is AFM sending incorrect voltages to the ECU causing the car to over fuel/under fuel! i have had similar issues with a Z32 in the past (or AFM in general)
Edited by Frosty
you sure you havnt got a vacumn leak? Ive found with mine that raising the boost is blowing out the intake manifold gasket, when that happens its either too lean or too rich, runs rough
I put boost down to low after tht but prob still there
get a can of wd or crc and put the straw tip on, then try spraying round the intake manifold gaskets and bov while its running
if it starts reacting then its confirmed, and check the clamps are tight
Edited by AngryRBGTX
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
