Ok car was goin perfect but yesterday morning it suddenly had like no power when i accelerated, it would do the turbo wind up and all but just no power, later the car went weird wouldnt rev past 3.5 rpm, smoke coming out exhaust, hunting idle, misfiring. I replaced spark plugs, tested coils (splitfires), check aac valve, check for vacuum leaks checked maf, checked intercooler.. Things done before prob i adjusted boost and put 20 dollars prem fuel in car.... Please help im seriously stumped car has fc commander, splitfire coils, stock bov, pod filter etc. 1994 r33 manuel
Edited by Nige1
I'm having the same sort of problem, car won't idle, misfires, heaps of black smoke. I haven't even tried to drive it, won't hold revs. The day before i took the coil packs out and taped them up, to fix a miss at boost, which it did fix. gave it a bit of a hiding and the next day it wouldn't run. just put a brand new set of yellow jackets in there, changed plugged, can't find any cooler leaks or vaccuum leaks. cleaned the maf
just about ready to try get it towed to a mechanic
I know what you mean, mine drives rough when it hits 3.5 rpm it starts misfiring hard and revving out and the idles fine until i rev it then it goes to stall but regains it self idles shit for a few seconds thn kinda goes bak to alright but not fully
have you checked it....im assuming a Z32? from what your saying it seems like it could be playing up causing your car to over fuel (at a guess). Start there! try cleaning it. Try disconnecting it when the car is idling there will be tell tale signs. If you have a spare or know someone try replacing it...
Me and mate have narrowed it to either afm, bad petrol or the fc commander.... Does this sound possible??
my guess is AFM sending incorrect voltages to the ECU causing the car to over fuel/under fuel! i have had similar issues with a Z32 in the past (or AFM in general)
Edited by Frosty
you sure you havnt got a vacumn leak? Ive found with mine that raising the boost is blowing out the intake manifold gasket, when that happens its either too lean or too rich, runs rough
I put boost down to low after tht but prob still there
get a can of wd or crc and put the straw tip on, then try spraying round the intake manifold gaskets and bov while its running
if it starts reacting then its confirmed, and check the clamps are tight
Edited by AngryRBGTX
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
