Hey guys i know this is bit of a hard one but does anyone have a guide for all the correc timing for r33, i wanna check mine and see if it normal. Also is 7/11 dodgy for fuel i put some in and my car just went shit idleing, smoke, not revving past 3 rpm but after injector cleaner it seems okay but engine lights still on
https://www.sau.com.au/forums/topic/420869-timing-question/
The only timing you need to be concerned about is base timing at idle. In general, the ECU expects the engine to idle with timing around 15BTDC. It assumes that this is set correctly, and all other timing is based on base idle timing being correct.
As for the dodgy fuel, if you filled up shortly after they received a delivery, then you might have got some crap that was stirred up during the tanker filling the underground tank.
https://www.sau.com.au/forums/topic/420869-timing-question/#findComment-6770487
Not entirely true. The timing at idle will change. You need to disconnect the TPS (from memory) on r33's to put it in base idle and it should sit at the base timing then. As long as your idle isn't going nuts it should be fine. 15 degrees is what it needs to be set to
If you have a STD ecu then it takes care of the rest. If not you will need to take it to a tuner to get the timing modified
https://www.sau.com.au/forums/topic/420869-timing-question/#findComment-6770617
Sounds like you have AFM issues. Check the AFM plug. Do you have an oiled air filter?
https://www.sau.com.au/forums/topic/420869-timing-question/#findComment-6770684
Cleaned it, cleane plugs i dont know how to resolder it and i cant get the top off
Found this ------------>>> http://www.skylinesaustralia.com/forums/topic/113284-fixing-your-rb26-afms/?hl=resolder#entry3274027
It's for RB26 MAFs but it should help. :thumbsup:
https://www.sau.com.au/forums/topic/420869-timing-question/#findComment-6771103
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
