Pedders has been a swear word since forever.
I wonder if different branches might be franchises.
I know that if I were an expert who owned a Pedders franchise, I'd be worried about any fly-by-nighters or even apprentices who could bring the name into disrepute.
I believe that the head of the Penrith branch does good work + he's on the committee of the Lower Blue Mtns Chrstian Car Club (associated in turn with the Nissan Sports Car Club).
  • Replies 50
they look exactly the same to the ones i purchased from option 1 in queensland. i had them on my car for more than a year and in that time i have been to Barbagello (waneroo) raceway atleast 5 times and given it a general hammering, hills runs etc and have never had any issues. nor my mechanic raise any concerns over the set up which i installed. although i am not a mechanic by any means.
from the pic you have post it looks like about 2 threads where done up and the locking nut was not tightened either and there appears to be no loctite or similar on the thread. who installed these? and why wasnt this picked up when it was aligned.
i am in no way affiliated with option 1, i am aware they are "china" however they appear to have held up very well in the application i have described above.
i would be looking at the installer and not the manufacturer / supplier
I installed them myself and got pedders to align them. it was screwed it 2 threads off the hole thing I never put lock tight on for the simple reason that it has to be adjusted and what's the point of putting lock tight on if its got to be undone was I ment to?? if had a talk to a few mates in parts shops and been looking around to try find the answer to why it happen and what I have got back so far is that there is about 50 good to 2 bad sets one of the shops had 3 lots come back with bent bars you must had just got a good set.
iv been stuck working late so I haven't had a chance to get more picks all the problem was its the thread failed and ripped out bending the top arms it was all installed and aligned correctly and this hole post was to warn people that are buying the same kinds of things to have a good look at them before putting them in cars trying to prevent people from having the headache that I'm going through now and out of pocket $1200
they would all have different workers lol just there products and service is way over priced $220 for steering alignment is a bit crazy
$135 for a seriously good job on the GTR at capital steering and susspension down ACT way.
Did camber, caster, toe and alignment
and Tez your right it depends on who's employed in the franchise so cant paint all Pedders with the same brush.
Although they dont seem to attract or have expert experience. You need a Master in the trade and some good Apprentices to keep in business.
I've seen so many of those cheaper arms do exactly what those ones have done.
There is nothing wrong with the arm other than an incorrect thread cut for the rod end.
Typically I install them and set the car up then remove the arms and weld the things together. Rod end wears out just chuck the whole arm and buy another.
that would be a perfect option the thread was the only fault
Is this implying you installed the lower arms with only two threads holding the large thread to the arm?
no opposite that when I installed it they were totally in and when it was adjusted they were turned twice extending out 2 threads
The majority of cars I've setup with these have had absolutely no need for them.
They are heavier than factory arms
They are more prone to failure
90% of them are installed incorrectly and never setup properly usually having poor rear bump steer.
They are prone to coming loose
Rod ends wear faster than ball joints
They are good for widening track and gaining camber
Correcting roll centres on some cars
Quality ones are stronger than factory on cars bouncing from ripple strips
Yeah I dare say it was an issue with pedders. Adjusted one side a bit, went to the other side and did it then forgot to tighten everything on the problem side. If you were driving normally it seems a bit coincidental that it happened just after leaving a pedders store where it had been worked on
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
