So a friend recently purchased a R33 GTS-T, he's taken it to the pits to find out what needed to be done to get it registered it the ACT, unfortunately, they picked up that the chassis rail is damaged.
Question is, has anyone experienced a damage chassis rail and the cost in getting it repaired?
He doesn't know the extend of the damage yet.
It's booked in next week for assessment.
Cheers for your opinions.
https://www.sau.com.au/forums/topic/421143-damaged-chassis-rail/
* Sometimes the rail is irreparable > replacement of the rail OR the car can't be blue slipped
* Sometimes the section can be boxed > welded
* Sometimes a hole can be drilled through the rail > threaded > pulled down
Booked in for next week. Fingers crossed it goes well.
The RTA did say it's repairable (Whether or not he knew what he was talking about), but hopefully it is repairable, that's my main concern atm.
(OP is referring to me).
What came back as so expensive? what did they say?
It's not on paper as of yet because he didn't quote the parts (He had to ask Nissan), however, the 2k so far is for the labour, enlightenment machine ($500) and signing the paper for RTA ($500). The quote isn't down on paper due to the quote unfinished
, but I need 4 segmented parts, which is an unknown cost atm.
It feels retarded, but cheapest in town apparently. I didn't notice the damage, but it's pretty bad. What is more retarded is that the car drives perfectly fine and perfectly straight. It's just the RTA being dogs.
Does this car still have valid registration in another state? If so, which one?
+1 for pics!
It has 1 month in NSW Rego.
Once the lad gets the full quote he will send me an e-mail with everything. He just needs to make a phonecall or two.
I'm pretty much seeking a R33 SR2 rolling shell as of now, unless the quote is going to be cheaper then I expect.
Don't NSW cars need to be inspected for rego renewal? where as in ACT they can just randomly call for an inspection?
Change of ownership I'm guessing is mandatory inspect in ACT & NSW aswell. (Jeremy only just bought it)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
