The guy at my gym said chinups are much easier and work more of your biceps. He suggested I start with chinups, then go negative rep pullups and work up to a straight leg unassisted pullup which he said is more lat work.
Fair enough, I like chin ups so will keep doing those.
My numbers can be disregarded as they're not in line whit this thread sorry.
For everyone else playing at home.
http://www.aworkoutroutine.com/pull-ups-vs-chin-ups/
They are easier.
His advice is wrong.
Partials of the pullup (at the top of the range) combined with negatives are where you should try and start. Most people can't do a single pullup. I gave my son this version of beginers the other day. He couldn't do a single. He can do 5 full now within a short period of time.
Dribble....... Lots of rubbish in there it's hard to know where to start.
So how many chin ups can you do Rev? I'm guessing 30+ if you can do mid 20s pull ups and chins are easier?
No idea. I don't do them. I can tell you that there is far less correlation than that article will lead you to believe. It is very common for people to be able to do 10 chins and 0 pullups.
but I take this slowly as it comes at the end of my routine and my forearms/elbows are usually fatigued by then and I've strained them once or twice.
Any that's my two cents.
The locked postion of chinups can give you some injuries in the forearms elbows. Moreso than pullups.
Is there a consensus about one being easier or something? I've always preferred having a supinated grip as it's easier on my wrists.
It's setup that will determine the angle of stress in the arms and shoulders. When doing a pullup, you want to look upward on the way up till just before the top. This will help tilt the body into a better postion. The chinup is more challenging on the elbows as this technique has little effect. Higher engagement of the bicep means the elbows are set to take up the fulcrum loads, you really only have the width to play with.
To be fair here, any of Leesh's attempts at pullups or chinups have been done straight after her volume training on lat pulldown...which she does at close to bodyweight...so I think fresh off the bat she'd be able to knock out a few reps of pullups.
I started doing negatives of chinups today and then did my assisted pullups - I can get half of a regular chinup out now! Cut the assistance weight in half, though chins/pullups are a movement i'd also not done much of until lately, in favour of lat pulldowns.
Haven't updated for a while, but I'm now
13
13
12
11
10
10
15
13
12
11
(5 minute rest)
13
I find this exercise interesting, because it's the only exercise I do where I shoot for maximum resistance straight up, without a warm up. I guess this is because of the static resistance level, but I sometimes contemplate whether I should do a few reps as a warm up and then go hard, or keep doing what I'm doing.
Either way it's been working, as I've been able to up the reps in the first set by 1 each week. This should theoretically bring the reps of the second set up with it, and so on, as my muscles adapt to higher numbers and follow up sets stay relative. Same way 1RM training increases volume, I guess. So the important thing here, is being able to get that "1 set max" up. 20+ would be a nice place to be, for the short term. Maybe then I'll look at weighted pullups.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
