  • 3 weeks later...
The muscles that are involved in scapular stability need a warm up sometimes Birds. They need to be fully activated to give stabillity. The funny thing is likely that part. Some days you will need to wake them up. Other days , you might have done some movements prior that have activated the muscles. It will effect the pullups by a few at least.
Just hang and squeeze the shoulder blades. Leave the arms straight and just get the lift from the movement (will only be an inch or two) Do about 5-6 of these , then have a go after a little rest.
Advanced version (more of a training on it's own, so forget pullups on the day you do them). Go to the top of the pullup movement or just below (say eye or forehead level). Then perform a shoulder squeeze in and out. It will have the effect of you moving towards and away from the bar.
It's advanced so don't push it if you struggle with them.
  • 5 weeks later...
19
16
14
12
Haven't made 20 since I first got it - as per my spiel about pull-ups being a funny thing. Have made some progress in the follow up sets, though, which is always good.
Hard to believe the third set used to be my max reps on my first set...
20
17
New pb for second set!
Hopefully crack 21 soon.
Could be truth to what you said rev; I was shooting some hoops earlier tonight and that's always a good warm up for the shoulders/scaps. Though I also skipped a couple gym sessions earlier this week, which may have given me some lat muscle rest.
Well you can't have the Racing car ones because they are blue and society states that only boys can wear blue.
You are a girl, you must wear pink.
(Yes I think it's dumb too, but I'm sure when the time comes my grub will probs want the pink ones).
I friggin hate pink. Black is where it's at.
20
17
Hey birds,
How much rest in between sets?
5 sets right?
Number of sets varies for me, sometimes I do 2 and sometimes I do 5. All depends how much time I have left, how the shoulder is feeling and how fatigued my muscles are. Rest is usually about 3 minutes between sets.
One thing I had found to help with pull-ups is to do them slowly. You would think hanging there for longer / slower reps would disadvantage you, but it's speed that hurts because it throws your body balance off / starts you swinging, which upsets the motion and costs you reps. Slow and steady leaves you hanging nicely and every rep is without a swing.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
