Okay well tonight I hit 5x140kg on my max set after doing 8x130kg last week. Will do 140kg again next session and I hope to get 6 or 7 of them out.
My 1RM is 170kg, but I haven't attempted 1RM for a few weeks, so it should be a bit higher now that I'm approaching that figure with my working sets. I love how 1RM and working sets compliment each other on a back and forth!
My current goal is a 200kg deadlift @ 80kg, which I'll be very happy with.
Do ppp and you will be there in no time man.
200kg might not seem like anything in the powerlifting scheme of things, but it is definently a tidy 1rm for your average gym goer!
Edited by Mitcho_7
I haven't plateaued yet, so will just keep doing what I'm doing for now. Yeah man, a year ago I didn't think I'd ever lift close to what I'm doing now...stoked! Think I'll be very happy with 200.
Got out 140kg x 6 tonight...grip gave way on the 7th, just before lockout. Afterwards I couldn't open and close my hands, lol! 3 minutes later and I pulled 150kg x 3.
So...should try for 7 next week or crank the weight up and try for 150kg x 5? Be interesting to see how I do on that 1.5 x bw deadlift challenge now...might have to revisit it in a few weeks.
I sit there like a cripple with my hands all closed up for about a minute before they slowly start to open after deads.
Then another minute for the skin to kind of relax.
I reckon low reps and high weight work better for deadlifts.
I want my back and legs to be tired before my hands give way or before it becomes cardio (5 reps plus)
After doing deads in the 8-12 reps range for a while and then doing 5x5 and PPP for deads, I definently like the lower reps. Sets of 5 are probably what I like doing the most, but singles and triples aren't bad to mix it up.
Why not both?
90 x 10
110 x 10
140 x 7
155 x 4
Had no grip issues tonight, cooler weather = no sweat. Next sesh: 160 for reps.
I'm using chalk, whenever I can find it / steal it from the cross fit section at the gym. My grip is never an issue for 1RM attempts, it's the holding of the bar for extended periods of time that seems to do it.
I don't think I have the strength to lift 200 yet. I'd guess 180, maybe 185 based on my 1RM of 170 when I was doing 120 for 10 reps. I will start training the 1RM again soon, though. Took a bit of a break from it when I stretched a back muscle.
Funnily enough, the older ABC bars have better knurling than the new Ironedge bars we have :/
depends on if you are talking 1RM or reping sets and even then you can do sets of 1RM starting at 100% like below
1RM
3sets of 8 - 12 say 100kg
1 x 110kg
1x120kg
1x130kg
and so forth increasing until failure to see what your 1RM is. obviously you get tired but then you would start at say 80% of that 1RM next week
as for 7x2 i ment max weight that you could do for 7 sets would prob be 130kg instead of a 100kg for 3 sets of 8-12
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
