oh, so a random Guy with a low power setup claims such massive differences with no dyno proof, and that means somehow I am losing heaps off power to a non existant coil issue?
cool -__-
cool -__-
Whoa guy - why so defensive? If you haven't tried the coilpacks back to back yourself, why are you so strongly convinced there is no difference?
Sorry that came across a bit harsh. Fair point, but when a combo makes the expected power, and comparable to others, I dont believe im losing out on any power. The people that pick up power are doing so because their old coils werent working properly. Actually losing lower by changing coils (unless the new coils are faulty) hasnt been proven. There are back to back tests that show there is no power to be had by replacing functioning coils with another brand.
im not willing to do my own back to back test, but I will have a set of yellow jackets available soon, as I am going to use ls1 coils I got for nothing. If anyone wants them, they can have them so long as they do a back to back test when installing them.
Ben
Thought I'd save some coin by buying the JJR (red) coil packs...
15 months later = FAIL (stock turbo@10psi)
BTW - My tuner said that the popping/misfiring under boost caused by these POS coil packs could be as damaging to the engine as knock!
Replaced with Splitfires...
15 months later = SWEET (3076@19psi) never missed a beat
Not only did I not save money by going cheap... it actually cost me and extra $400!
Edited by Checkbuzz
dude, heaps of people make twice your power with yellow jackets. I am making 274rwkw with them. explain how that can happen if they are so shit?
he didn't say these coils won't make power, he said on HIS setup he made less power with the yellow coils then he did with the stock ones and how do you know 1) he didn't make less power, and 2) your setup won't make more power by putting stock coils on your car, you've said our not will to try it but are willing to take a shot at someone that has
cool -__-
why so angry, he is just telling us what he has experienced with his car, what does his power setup have anything it do with this issue if anything the fact his setup is so low power showing that kind of difference would mean it would be worse on a mild setup like yours and even more so on bigger setups
can you prove he didn't and if your not willing to test them how do you know you don't have an existing coil issue or won't make more power by changing them and if you don't have an issue and these coils can make the power why are you changing them ? cause, and please correct me if I'm wrong, free or not the LS1 coils are not a plug and play setup and remove the factory look giving a greater chance of a defect if pulled over
i made 360 rwkw on a neo rb25 with yellowjackets and plugs gapped at 0.8mm running e85.
have heard of others not having such luck with them. same goes for splitfires.. success stories and dramas everywhere.
my motor now runs MSD blaster coils... the spark these babies throw off is nothing short of frightening
Thing in China is. If one business makes money by copying some thing (doesn't mean it works), then every one else follows. They will also try to produce and sell them at a cheaper price. Externally they appears identical, internally they could be very different.
I think you missed his point, he made less power on his setup with them so if you change the yellow jackets to stock and you might pick up x amount of power on your setup
Exactly the point, and to make sure the testing was fair i ran them all on a stock car with minimal mods(not even my car) I did the tests quite a few years ago simply because i was curious to see just how much difference there was from coil to coil, the only new set of coils involved in the tests were's the yellow jackets, the stockers and splitfires were old ones of previous setups of mine and had done easily 20,000km's on the split fires and the stockers around 80,000km's
cool -__-
Yes thats exactly it dickhead. why dont you go and pay for dyno time to test some coils and see what results come from it and tell me how much you feel like sharing your results for others to gain from?
I performed the tests over 3 years ago stock car as i thought it was the only fair way to test back to back. I hope the shitty yellow things have improved A LOT since i tested them but i cringe when ever i see them on a car. The sad part of all with the test i performed is that the car idled nicer and felt smoother with those shitty yellow things on it but once the tests had been done both myself and the owner of the car where extremely suprised and shocked.
Spark is not something you should cheap out on but if you are on a tight budget look into retro fitting LS series coils which can be had extremely cheap from the states. If you want the best there is out there.. BPP's CDI setup is the most impressive bolt on solution but comes at a cost and its not a complete bolt on plug and play.. you do need to snip and crim the 7 ignition wires into a new plug(supplied) to suit the new ignition harness.
No need for name calling...
So we could assume the coils have improved, as there are plenty of people making 250+ with yellow jackets.
At the end of the day,i don't care. the coils were on the car when I bought it, and I will be going to ls coils as they are clearly heaps better. But I seriously doubt I would make more power as there is no issue currently.
you would be surprised how much they pick up with a larger gap and decent coils....
If my mate (Sloane) goes for the splitfires and gets rid of his yellow jackets, I'll ask him to put the car on the same dyno and see if it will run more than it's current 370.8RWKW.
Interestingly I definitely felt improved power output going to the yellow-jackets over the stock coils even though I had no issues with the stock coils. But then again I also indexed the new plugs I put in by facing them toward the intake ports.
dont know.. as no other coils would work haha.
best part was the MSD blasters are 70 each (need 3, run wasted) plus a set of custom leads and an ignitor. strongest spark ever
Ergh if they are so cheap why did I blow ~$500 on yellowjackets If I could get these MSD blasters for that price?
Any info/links?
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
