Damn that's a good time I'd be very happy with that.
I wish I could get my run in except they've cancelled for the last two weeks due to weather :(
Soon the AR-X's will own best times in 3 states.
1 may even have the Australian title! :P
I can't wait to get the rs260 down the drags, sort the clutch out then before the mods will do a run to see what mph I'm getting at the end or the 1/4 for bench mark!
Hoping ill get it lower 60 foot than my VL! Don't think ill get it lower than what the VL has run! If I can get it as low as what rbnt got his rs260 up here 11.8 ill be very happy :) ps I wish the track was only 28 degrees most of the time it's in the 30's plus
Any ideas on what a completely stock 250t rx 4 would run?
Im heading to the Eastern creek drags on the 22nd if anyone else is keen.
Possibly keen. Just gotta see if my car is happy before then.
Would like to see where I'm at currently.
Had my first run ever at the drags last night.. Only got 4 runs in. The best I could muster was 13.4 pretty happy with that..
The car kept getting really cold as we were having over hour waits between runs..
Hopefully keep improving the car and the tune...
well done great time:)
It's a lot easier to keep a car warm than to cool it down, mine was heat soaked and I could do nothing about it. Other guys were putting bags of ice on their coolers and engines to help combat the heat.
I should probably get up to Heathcote soon now it's winter and get a time on the current tune, I am only going down in power from here. (perhaps back to a highflow soon) I have had my fun...
I had two similar runs at 13.4 at 102-103 mph.
I'm amazed at how much the brake cut makes a difference I forgot to turn it on for the first two runs :( and got 14.5-14.2.
Yea totally agree Scotty but if the transmissions cold would that effect times etc as its not possible to warm it up without moving anywhere?
I'm sure there are many factors that could lower my time ;)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
