Hey guys im just wondering what is the maximum safe boost level for a r32 gtst. I just bought a r32 its got a few mods like 3inch exsurst, walbro fuel pump, hks filter and apparently a high flow turbo but it looks stock without taking it out. Without a boost controller its spooling up to 0.8bar or 12psi its running a little ruff and smells really fumey.
https://www.sau.com.au/forums/topic/421467-maximum-stock-psi-for-r32/
Stock boost is 10 psi. 12 psi is easy with just a big exhaust (and possibly a bigger intercooler to reduce restriction). No boost controller needed.
So, whether or not there is a high flowed turbo on it, it could easily be running 12 psi with no further mods needed. The ECU will be perfectly fine, no emo R&R business going on, because it's an R32, not one of those stupid R33 ECUs. But it will almost certainly be running quite rich, because the stock maps are very rich at elevated boost levels, and it is quite possible that the ratty old coilpacks are not handling things real well. So it's not surprising that it might smell a bit fuelly.
Oh, and given that it has a big fuel pump on it, it will almost certainly be running a lot richer at high load&rev than it normally would. The original fuel pump would not be able to to maintain full pressure at really high flows, so pressure starts to fall off. Mixtures lean out. ECU is running in open loop, so is just working off the maps. Everything is good. Bang in a big fuel pump and the pressure stays high up top and the mixtures get richer.
Cool cheers for that info. It really dosnt like to idle cold it wants to stall one minute the rev at 2 grand the next till its warm. I replaced the tps and am about to do a service on it. There something wrong with the motor just not sure what it is.
I ran a stock m35 Stagea ceramic turbo up to 19psi on e85, I ran it like that for 5 months while I got the parts together for the GTX. Either Nissan started making the ceramic wheels stronger, or it is the age of the turbo that makes it fail quicker. (heat cycles and old worn rear bearings)
Theres a blowoff valve on there but I blocked the hose to it because the blowoff vavle was leaking (its really old and shity looking ). Is there a way of actualy telling whether it is a high flow turbo with out taking it off. Do the stock ones have a stamp on them at all to look for
There's all sorts of different bell curves associated with these things. Some will die at stock boost. Some will last only a short time at high boost. Some will last a long time at the sensible limit boost (whatever that may be for a given turbo type and engine). Some will last a long time at really high boost. Manufacturing tolerances, age, past treatment, etc etc etc. They all stack up.
My RB20 turbo ran at 17 psi for quite a while, then I backed it down to 14 psi and it ran like that for 10 years. A mate's died at 12 psi a month after he put the exhaust on (and the boost went up as a result).
there's a start, put the stock one back on if you're running an AFM with a stock ECU... and to answer your question not really, I would just pull off the intake and see if the comp housing has been machined
It had a microtech on it when I got it. It ran like shit and didnt aant to start so I checked the computer and it was all corroded so I put a standard one on and now it starts but dosnt want to idle cold at all I have to sit there and
Keep it from stalling till its warm. But even then if I turn the aircon on it will die start away. I will have to buy a new blowoff vavle and do a minor service to it and see if thers is any difference
You might have larger injectors running on a stock ECU, all makes sense now.. the car had a high flow turbo, an aftermarket ECU, so most likely it has larger injectors to compliment the rest of the setup.
I would see what size injectors they are, if they're bigger either you install the stock ones OR get another aftermarket ECU, rescale the injectors to suit then bring it to a tuner.
ummmmmmmmms.... can't remember on the top of my head what RB20DET injectors look like, but they could also be 440cc GT-R injectors.
Can you trace the wires back to a resistor pack like so:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
