.... 13.7 for a relatively stock ls1 in a reasonably heavy car is pretty good going. Your 33 is about the same weight as a commo with no interior or fat chicks. Most people have no idea how fast a flat 13 sec 1/4 really is.
N20 time... :yes:
I do. And this car should be getting close to them IF Nick setups the rear suspension AND tyres.
I'm in a heavier car, running 13.004 down the quarter at 106MPH.
Nick ran originally 13.9@106MPH in a car that is way lighter than I am.
Probably a smaller torque converter would help get this thing off the line easily, OR really really sticky rubber. Chasing more power is not going to help if you are already struggling to put power down at the half way mark...
I have et slicks sitting there, I never dropped my tire pressures the other day and I'm on stiff coil overs :)
I want a 12 second street car... It's just a matter of time
This is true... but for 2nd run at the drags with a poor set up it's not too bad.
As for improvements... Better tires, 0 static rear camber, softer rear springs/shocks, re-angle the rear cradle, adjust ride height to straighten drive shafts, lighten the car more, VHT tire prep.... list goes on. How far do you compromise???
No need to lighten it, it just needs a sensible suspension setup put in it.
Softer rear shocks and springs, get rid of the epic camber, and run low 13s.
PS: My 13.004 was on my first EVER run at the drags... ;)
But Pineapples, different shocks/springs, realign suspension, DONE. Go run flat 13s on same power.
  • 1 month later...
Not really an update but a bit of car activity:
Dropped the oil and changed the oil filter and air filter yesterday preparing the car the the little run it got a Queensland raceway with the supra club yesterday. Overall the day was good with some mighty fast supras there, an even a 1uz powered jza80 (which I actually chopped down the main straight ;) )
So yeah just a few shots from the day.
Big thanks to QLDSC in particular tara and scott i know how much effort goes into organising events like this aswell as SAU Qld, Mike, Tony, Scot, Boz etc fantastic to see the club moving forward and getting back into some driving orientated events :)
Cheers
Cheers
vids of you chopping v8 supra
Waiting for boz to finish editing the video, it was closeish actually but this definetly had more grunt must say the thing sounded sexy as sin was basically straight piped
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
