Hey all,
Will be entering my R33 GTR and also my 355 stroker yellow torana with yellow interior! Cant miss it!
I went to the last one just to watch, expecting to not like it. Was expecting Bogans, jap haters etc etc BUT i found it to be really good.
Most people there were very well behaved, marshells were friendly but wouldnt tolorate wankers.
very well run and things to see 24 hours a day!
Definatly worth the drive to have a watch!!
http://www.mallala.com/events/mallanats/
Car Clubs
Cruise to Mallala with your club or your mates and we’ll organise an area for you to park together…and put your club cars on display! Old school, new Jap..whatever…bring it along.
Find our ‘Clubs Special Offer’ below, which has discount tickets for clubs. Note: Offer only applies for genuine clubs and clubs must park together.
MallaNats Car Club Offer Here
hmmmm?
Ah damn mate thats no good...
Totally agree, way to many cars, WAY to many dickheads doing burnouts on cruise the track to have a decent drive. And most events are aimed at the V8s. I just cant get into the whole burnout pad event!
Not sure if ill enter the GTR again but will take the torana in again
  • 10 months later...
It wasn't to jap friendly till I won the drags and go to whoa . They all came around in the end but . Im hoping me and my brother v8 turbo sigma see it out together for a laugh. And ill be running slicks not sliding all four first and second . post-103277-13938130649304_thumb.jpgpost-103277-1393813122367_thumb.jpg
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
