hey guys i just recently bought an r33 gtr v-spec and at light braking pressure at speeds around 40kph and under i have an extremly loud squeak from the front brakes
i have been told that brembo's are known for squeaking like this but would like to try and fix it
the calipers are factory and it has 2 peice front discs unsure of brand i think theyre aftermarket and unsure of the pads
i have been told to just try blowing the area with a blow gun or greasing the shims just want to confirm
any help would be great thanks guys :action-smiley-069:
https://www.sau.com.au/forums/topic/422236-squeaking-brembos/
Make sure all the shims are there as they seem to go walkabout :)
Rotor surface may be glazed, you could get them very lightly skimmed or similar.
Pad type seems to affect the amount of sqealage too, ie high metal, high temp type pads are bad for it.
Thanks guys I checked the pads and shims on the weekend they were glazed though all shims where there so just roughed them up on the concrete a bit did nothing and still plenty of meat on the pad might have to try different pads.
Any ideas heard ebc are good but don't know much about pads
Nobody uses RB74s from Race Brakes anymore. For spirited driving they are not bad things and are cheap. Dusty but they are quiet. If you get over half way through the pad and decide to drive like a lunatic on them they can deteriorate but takes track work really to get them that hot
Have you tried using emery paper on the rotors yet? You will need something to spin them on though you could improvise using the back axle.
Also do you know how many shims it had from factory I can't remember off the top of my head if they run one or two per pad.
Edited by pf.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
