R33 Stock Bov Flutter Sound - Whaddaya Reckon Of This?
Techinically its not legal as its making noise.... You will soon get over it as it will get old quickly!
This will not get the bishes moist!
  • Like 1
To your dignity.... yes....
There are SO many topics on SAU about BOV's and not running them, blanking them etc............
My understanding is that you could bend your turbo blades. By Blocking off the BOV the built up pressure that normally gets released to atmosphere or recirculated, has nowhere to go but back though your turbo and as such temporarily stalls the compressor, which can bend or brake the blades, and the stalling of the compressor is what gives the flutter sound.
  • 3 weeks later...
  • 1 month later...
Lawl! These threads always deliver!
But the whole flutter thing will soon be annoying for a daily drive!
AND you can get EPA's based on it anyway as its still creating a sound!!
In other words, DONT DO IT!
You f*#@Kin idiots..... The 'flutter' sound is called compressor surge. it is NO GOOD for your compressor blades, it slows down your turbo from spooling in between gears and in worst cases, f*#ks up your compressor blades.
Sometimes when people get too ambitious with sizing their aftermarket turbo and get the housing sizes wrong, or over fueling at idle because they didn't reconfigure their fuel map properly after they fit a bigger turbo, compressor surge OR 'flutter' is the result.
The whole purpose of having a BOV is to release the excess boost so it doesnt slow down your turbo in between gears.....its for response.....WTF would you sacrifice response for a sound ?????? fu*kin idiots
Man, I really wish these kids learn about the fundamentals of engine mechanics before they make a total dick of themselves or worse, totally ruin their cars.
Edited by NATAS
The whole purpose of having a BOV is to release the excess boost so it doesnt slow down your turbo in between gears.....its for response.....WTF would you sacrifice response for a sound ?????? fu*kin idiot.
You sir are a f**kwit
Guest
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
    • Also, it is just about triangularity. The less angle, the easier it physically is to do. Think of the amount of slip you're getting, as how hard you need to push an object. More slip, equals pushing way harder. Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart. However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • It's the angle of the ramp from the vertical. You're measuring from the horizontal. To convert, take 90* minus your angle reference = Nismo Angle.
    • I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles. Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley.  I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
