  • Replies 70
Not sure your weight figure is correct.
An ARX is 1780kg and an RX is 1680kg.
But if you want to lighten it have a look at changing Electric front seats or removing some of the electronics.
There are not many other places to loose weight as the subframe and suspension are all alloy, bonnet is alloy, boot is plastic composite.
On the upside, all that weight is near perfectly balanced on the chasis with 52% on the front axle and 48% on the rear.
Enjoy.
Nope, RX is awd, as is the RS.
Mine weighed in at 1670kg on the weighbridge at my work.
Considering a stock VE sedan is 1700kg, and even a fully loaded FPV ute is over 1800kg; I don't think there's much to worry about.
I know what I'd rather be driving in an accident.
Or any other time for that matter...
RS if you have triple gauges in the centre, RX if you don't. I think that is a safe measure, unless installed later, right guys?
Or plug in your VIN into something like epc data for the run down.
180sx: 1150kg and three times as powerful as your car.
You Jelly?
^ Yes, yes I am.
I put mine (RS) on the local weighbridge & it came in at 1800kg with me in it, after I had removed all the ususal suspects (spare wheel, tools, sub, mats etc.). All the lux adds weight, no doubt.
I'm not concerned though. This article on the weight of the R35 GTR gives me some peace. http://www.topgear.com/uk/photos/kazutoshi-mizuno-nissan-gtr-interview-top-gear-2012-02-23?imageNo=1
With the right tyres, our cars handle better in torrential rain than most do in the dry.
Your in a wagon who cares for weight loss. Rip out your high flow vq and send it to me. That should save you a good 300 kg, take off your wheels and stick it up on blocks that will save you 100kg give or take. Take out your r35 gtr seats, bc's and swaybars and that should save another 50kg .So that will make you about 250 kg heavier than the 180 but you wont be moving far....
I care for weight loss funny man. That's why I started the thread.
But all you're going to end up with is a noisier, harsher, less pleasant car to drive.
And it might accelerate a poofteenth quicker, or save a bees dick of fuel?
If weight saving was your primary concern; why on earth did you buy a Stagea?
If you do anything to your car that displeases me; I may have to kill you.
Lol, jokes. :whistling:
But seriously; don't. ;)
Edited by Daleo
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
