it ain't glamorous and it ain't fun... but when you do it regularly magical things start happening... an awesome exercise if your feeling stressed or frustrated... a proper squat session is like nothing else, it gives you an awesome appetite and you sleep like a baby
and it cures cancer... obviously
my old man is nearly 70, 65kg and does 5 sets of 20 reps with 60kg... don't let a senior citizen out squat you!
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802596
I was watching the fattest losers last night while eating a bowl of ice cream with cookies and maple syrup... and before it came back from an ad break, the commando was on giving a "TIP".
I cheered and did fist pumps like I had just won lotto..
There was the commando, Barbell on his traps.
And it goes something like this.
C - "Here is an exercise that will not only help you lose weight but also give you an all body workout and get you strong" Squats!
me - "here we go.. time to see some 1/4 squats to make sure the knees are safe"
C - "If you want, start with a broom stick to get used to the position... what you want to do is put the bar across the back of your shoulders, pull your shoulders back to create a platform there, have your feet shoulder width apart, take a breath in, then sink down and back keeping your knees out until you are at the bottom (he was well below parallel), then push back up. Everything moves up together, everything stays tight"
me - "Holy shit!!"
C - "get some weight on to the bar and start by doing 3 sets of 10 reps then increase the resistance. If you are over 40, you may need to be more careful of your joints.. I recommend *insert some brand of joint formula here*" (pumps out nice full depth reps as it fades off to an ad with the other male trainer and same joint care formula)
me - *choking on a cookie I didn't fully chew* "f**k yeah!! - Do some squats you fatties.. get that up ya!!!!"
Didn't even care that it was an ad for some shit.
Edited by TTT
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802670
inb4 Birds' squat thread
Currently:
60kg x 10
70kg x 10
80kg x 10
90kg x 5
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
Watch this space for big improvements, given I can only work legs at the moment. May start dropping to 5 rep sets, as my warmups are taxing me up top quite a bit...though its not as it I'm not making gains.
The ATG squat has a bias towards glutes and adductors, so I'm smashing leg press after squats to give the quads a good bashing too. After this and hamstring curls, I start walking like a zombie.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814200
if you want more quad work try front squats with an olympic stance
you could squat twice a week... do one day with high reps, light weight... sets of 10-20... then do a heavy day where you do very light warm ups then do 5 x 5 or even 5 x 3
in the above your mixing both... which as you say makes you too tired when it gets heavy
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814228
Or I could squat 4 times a week, 2 for light weights and 2 for heavy :D
Good suggestion though. Might allow my legs to recover quicker too.
Can't really do front stance, as I think it will aggravate my supraspinatus. I'm lucky that i can bend my arms enough for high bar. My quads do get plenty of work, don't get me wrong...but it's nice to add that little extra with the leg press and to finish them off in a way that squats can't without losing form. I was considering mixing up the parallels with ATG so that I get a bit more quad action going on there and have more strength for getting out of a half way hole.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814288
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
60kg x 10
70kg x 10
80kg x 10
90kg x 6
95kg x 3
Might add a 6th/1RM set to this so I can start using it to leverage my sets of reps and up their weight. 100 should be fairly doable for a start.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6818205
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
