Whole team is done with 8's, so funny watching their expression, pure relief. Actually Max, Dan and Zoran do them Saturday, they have 180kg x 8 for 3 sets, no wraps
Jack did 195 x 8 x 3, Emad 170 x 8 x 3 and Spiros 160 x 8 x 3, last night.
Everyone starts wrapping from the first week of 5's next week. I know Max, Dan and Zoran have got 205 x 5 x 3 sets next week, then 220 x 5 x 3 sets the following week. They are on the 275kg squat plan.
Whats your first week of 5's Nick? Youre on the 220kg plan arent you? Must be 165 x 5 next week?
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6818813
I don't find the initial 3 sets so bad... it's the pause squats and high rep safety bar squats afterwards that kill me... just not used to that amount of volume... it hurts my vagina
180 x 8... fck that!
Zoran and Max look so comfortable squatting... all my reps are ugly grinds lol
yeah on the 220kg plan... but I want 230kg at nationals...
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6818855
I wasn't saying he IS evil... I was referring to his ownership of evilness...
you're not buying that are you?... oh well, at least I spelt it correctly this time hehehe
back on topic... why have you retired!? your partly to blame for getting me into this shit in the first place, now your quitting!
at least come watch Dan Green and eat pizza
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6819597
60kg x 10
70kg x 10
80kg x 10
90kg x 6
95kg x 3
Might add a 6th/1RM set to this so I can start using it to leverage my sets of reps and up their weight. 100 should be fairly doable for a start.
60kg x 10
70kg x 10
80kg x 10
90kg x 5
100kg x 2
The 100 was supposed to be a 1RM, but it felt easy on the way up, so I did another :D
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6821809
80kg x 10 means a fair bit more than 100kg for 1rm
Yeah but by the time I get to the 100, it doesn't lol
Prolly could have done 105 or 110 for the 1RM at the end. Though it's almost time to space out the working sets. Maybe shift the 70 to 75 and 80 to 90; 90 to 95 and 1RM to 105.
As long as the weight goes up everywhere :)
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6822062
if you are actually going to try and go for a single, then go
bar x 10
60 x 5
80 x 3
100 x 1
then either 105 or 110 depending on how you felt.
then keep going up by 5 or 10 depending on how you felt etc etc.
obviously do it in a rack with safety bars or spotters.
Whatever you fail on you'd be able to do the next week with less singles before it.
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6822228
60kg x 10
70kg x 10
80kg x 10
90kg x 5
100kg x 2
60kg x 10
75kg x 10
90kg x 8
100kg x 3
105kg x 1 (died on second rep; thank you safety bars)
I think the leg press is helping a fair bit with squat strength, along with progressively stepping up the weight on squats. I'm tryIng my best not to lose form as I step up the weight...it is still very ATG...however...I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6825705
