Breathing all good?
yea catch can v4 has done the trip
have not had to deploy the scaveng pump just yet
thats pretty good considering 12x12 minute sessions half at 15psi and half at 19psi
Did you throw in a fuel cooler??
yea i did in the end
on the 12 session i had the tank at 1/4 and did a session after 4 laps the secondary pump got noise and the ecu went into linp mode ( fuel pressure protection) so we know that works
restatr car with fuel and all fixed
  • 1 month later...
minor update
been working on these fckers for a while
i want more stopping power
so 996/7 porka cup calipers
380mm full floating rotors(off getting machined)
new brake line, new pads
custom hub adapters and billet dog bones
i was very happy they fit under the 18's
just buy about 7 mm
rally sprint done and dusted
tops fun you guys should get out there
i almost died about 10 times
fastest time got me 10 out of 80
and more importantly beat the only other r33 gtr out there by 9 seconds( although he won a trophy for our class, should have checked they had me in the right class to begin with...lol)
my first ever youtube video check it... after it uploads
http://youtu.be/joAU_gEKMdA
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
