I am a mechanic guys I have been involved with and have driven very fast cars I want a turbo yes but I don't froth over turbos like some.
I don't mind having less power if I can use the power I have IE: racetrack style torque profiles.
I have seen rb30 heads that flow enough for 330hp which would want my engine to spin at about the mark I am looking for 8k which is where I will be shooting.
My engine stand comes soon dedicated to this build pistons are next $700 ill be contacting crankshaft rebuilders for a price to do the crank and I am thinking 26 rods.
The head is back to me before machining so I can work out belt's and other little things a mate just blew to 30's at the mattsuri comp so ill be having one for bolts and other parts.
Edited by pf.
Like a turbo car.......?
Nothing like a turbo car. The power will actually be instantaneous. If you have a turbo that comes on only over 4K, even once you're over those revs and stand on it, it takes time for power to appear. Sounds like some people may be surprised at how much a very driveable lower powered engine can still pull a lap time down.
I know, I used to have a cammed RB30 NA. Power and Torque was nice. Not blowing anything away but it was a nice delivery.
I'm just saying, theres a reason why car/engine manufacturers are going DOHC or Quad cam when in V configuration. Just remember there is no VCT with the RB30 head
But anyway, I'm not going to say anymore. Advice has been given, noone is forced to take advice, and thats fine. Everyone is entitled to their own opinion etc.
i actually meant the 5.5l new small block lol
But that is a smaller engine with new tech. A bit like how the rb25 was better than the rb30. However in this case the op is taking the smaller, newer engine and bolting on the old tech.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
