Ha ha.. if you can find a manual for gtst ill suck your......
No, but seriously, the bottom one is very hard to find. does anyone know where to get one?
I went to the bearing shop and they found another number on it:
sfo6a26vpxi
again its hard to read, the 6s look like 8s but i think they are 6s.
Ill try and get a photo of the numbers- no my cameras not up to it
Edited by D.I.Y. Mik
Ok people there are none to be found.
Nissan will MAKE a set for me, awesome.
However.... $150 each bearing (fair enough)....... $120 each dust seal (yeaow!)
Im saving my dust seals and repairing them.
No not like that, its a creaking sound not a clunk clunk.
That sounds like your wheel is about to fall off dude! dont drive it.
Go get it checked out by a proffessional.
Well I've got a full thread about it here and no one is replying, but the noise is gone, so it was either the trunion bearings or the hubs because thats all I changed.
http://www.skylinesaustralia.com/forums/topic/423302-had-both-front-hubs-control-arms-replaced-problems-now-worse-no-more-money-diy/
Anyone at least know the torque specs for when I re do the new control arms?
Ever since I had the shop put in the second hand ones, the steering feels really tight and I get tons of under-steer like some bolts are too tight and something is not flexing right.
I will be ordering new bearings next week and hopefully fitting them next weekend. Thought honestly I have no idea what I'm doing.
Edited by sonicz
  • 1 year later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
