Morning chaps.
Yesterday, I took delivery of my new 2002 Nissan Stagea Axis Autech model from Northshore Prestige. Having recently sold my R34 Skyline due to not being able to fit film gear in the Liner, I went on the search for a new car. I was looking for something cool, auto, with a bit of power, upgradeability, comfort and most of all, space to fit all the things. After having driven a few different cards (VE Wagon, Legnum, etc) I went and saw Ben from Northshore Prestige, and took the car for a drive. It basically ticked all the boxes, and I left a deposit on it that day. Its done 104ks.
After having the car for 1 day, my initial thoughts are as follows.
1) The suspension/body roll is horrible. I will definitely be investing in some swaybars to stiffen the body roll up a little bit.
2) The seating position is rather high. I would ideally like to put some lower seats in, but its not a HUGE issue.
3) The auto gearbox is one of the most sluggish POS's that I have ever experienced. This is something that will definitely get attended too.
4) The car feels very restricted. I would imagine freeing up the intake and exhaust will make it breath much better.
Other then that, I'm really happy with it. It talks to me in Japanese everytime I turn the car on as well, which was pretty unexpected at first.
I'd like to get a new dash facia so that I can fit an aftermarket head unit with bluetooth and ipod connectivity as well.
Can anyone tell me what wheels these are? They seem to be factory Nissan 18"s.
Pics: (I will get some better ones this weekend, these are the dealer photos)
Cheers,
Shaz
Edited by XS80ST
https://www.sau.com.au/forums/topic/423805-build-thread-02-stagea-axis-autech/
Hai new stag owner!
Great purchase. Looks clean as.
If you haven't already the forum has all the information you need for most of the points you listed.
Daleo for swaybars and brace. Justjap I think for BC coilovers?
Jetwreck for shift kit.
Scotty for dump and front pipe.
Unsure of the wheels? Look like wheels off an AR-X or something?
​Fascia kits are available off ebay and I'm sure there is a thread where you can use aerpro harnesses to accommodate a new head unit for the things you mentioned.
Edited by M35woah
Hey buddy,
Yep, been in contact with Scotty already about a dump/mid pipe. Will be throwing some cash his way as it becomes available. I have read all the positive results from Jetwrecks valve body upgrade, and will also be doing that as soon as possible.
Will hit up Daleo for the swaybars. I don't particularly want to go coilovers, so maybe just get some lowered springs. I saw there was a gent on here selling a set of eibachs for $200 at the moment. Also, brake wire cut mod is on the list of things to do.
Cheers,
Shaz
Congrats on the purchase.
Wheels are stock AR-X rims.
Goods springs are nismo ones. The rest pale in comparison IMO. Had eibachs, wouldn't go back. Your in the right track with the other things. Get some good pads and fluid in it to get the most out of the stock brakes.
Had an EZlip left over from a whole heap that I brought into Aus, so I chucked it on the front bar. I generally do this with most of my cars, as it stops the majority of scrapes and scratches on the front bar when bottoming out.
Looks okay too!
1EB8F94A-2B28-4554-B0BB-3FB9ECFDFFA2-103
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
