Hi All,
As you may or may not be aware, we are reviewing the Pro's and the Con's in moving our forum back to the Mothersite (www.SkylinesAustralia.com). This is a decision we are taking very seriously as this will influence the way the club operates. As the execs are not here to dictate rather facilitate the running of the club, we require the decision in the move to be voted on by our members.
The discussion is open to all members of the forum to participate, however voting is only open to paid members of the club. A blind poll will be launched in the up coming days and all paid members will be notified on the poll.
Here is a list of Pro's and Con's for moving our forum back to the Mothersite.
PROS.
  • Public Exposure
  • Traffic flow
  • No cost to the club to host our forum
  • Constant update to the forums - free of charge
  • Separate members area to be arranged in any way we deem suitable
  • Our own moderator within our club area
  • Page can be laid out as we wish
CONS.
  • No Admin control
  • No ability to email from the forum
  • Previous tainted history between SAuQLD and Skylines Australia Moderator/Admin team.
Here are a list of Pro's and Con's for keeping our forum on SAuQLD.com.
PROS.
  • Admin rights.
  • Mass email
  • Can layout the forum as we wish
  • As many Moderators as we wish
CONS.
  • Low public exposure
  • Low traffic flow
  • It costs the club to host the forum
  • Forum/site Updates required may need to be purchased
  • Less ability to do forum membership recruitment
  • All forum maintenance is to be completed by us
  • Less likely to build a rapport with other states due to lack of presence
As this is an important club decision, we encourage discussion and want to know your opinions before a decision is made. So please spend a few minutes thinking how this move will impact you and your club and feel free to ask any questions you may have.
Cheers
Scott.
Scott/Tony *raises can of redbull*
I believe my view has already been expressed many times over the course of the last month or so, but in my opinion we as a club would be better off moving our banter as a whole back to here.
I see no reason as to why members who frequent the whoretown/forum on the SAu Qld site can't simply migrate over here and talk the same level of er intelligent discussion in these forums.
So looking at it from that pov we have alot more to gain (a much larger base for members to come from) than what we have to lose.
Admittedly losing some of the exec moderator control is annoying, but moderator control can be delegated to specific sections of SAu Aus so why not simply limit our moderator power to the qld sub forum?
Basically I'm all for moving us back to here :)
There's a lot of... interesting... banter going on over there about this.
Yer I'm flipping between the two sites as I type now.... The problem is none of them will ever see this post AS THEY DON'T COME HERE!!! :rant:
CONS.
As far as I can see, this is the only valid reason to keep a separate forum. I think some adult discussion is required with some assurances from SAU that we will still be free to moderate our part of the forum as we collectively see fit. Things can often get rather awkward when dealing with power-hungry keyboard warriors... Thoughts?
This discussion has been had, between members of the executive and admins on this site. We believe that this issue will not be a problem any more.
Name names please Martin, who are you dealing with????
Names aren't important, all we need is confirmation that they'll let us run our own show... Which I cant see any problem with, why not let us run the qld section we're the ones that live here ?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
