Just wondering what sort of fuel reg you have and how you have it set up including how your reading the pressure?
I got a nismo FPR in mine and my car keeps pinging over 9psi so I assume its running lean, unless I up the fuel pressure real high, in which case it runs like a dog below 4000rpm.
Getting a new fuel pump these days as I have the stocker in there too.
Still not sure which fuel line I need to splice to read the pressure (R33 GTST)
Edited by sonicz
Measuring fuel pressure is easy and obvious. The pressure gauge has to go on the rail side of the reg (or in the supply line to the reg.)
So then the line in green here?
I don't get how a gauge can go in the "supply line to the reg" though, i.e what you said in the brackets. If you do that, aren't you measuring the fuel pressure from the pump, before the FPR, instead of after?
Any idea what size the standard nissan fuel lines pipes circled are? I already have a 100psi fuel gauge.
So something like this and two clamps would do the trick then?
http://www.ebay.com.au/itm/1-2-BILLET-ALLOY-INLINE-FUEL-PRESSURE-GAUGE-ADAPTOR-FITTING-/110769678546?pt=AU_Car_Parts_Accessories&hash=item19ca6328d2
$(KGrHqUOKjsE6Rhsh1hzBOs5,8CU(g~~60_12.J
Edited by sonicz
The fuel pressure reg sets the pressure UPSTREAM of the reg, not downstream. There is no pressure downstream of the reg. The reg is on the outlet end of the fuel rail.
As such, the line you marked in gree is after the reg and is the wrong one. The one you marked red is the right one. You can tell, because is comes from the fuel filter.
Your fitting is OK. But just in case you were thinking of it, don't cut your fuel line. Get another piece of hose. Remove your existing line from the rail inlet, put that onto the T piece. New piece of hose from the other side of the T down to the rail.
Thanks, man. I think that was the mistake I was making running it in my head. I'll follow the hoses tommorow.
You don't know the size of the standard Nissan fuel lines there so I know what size adapter to buy?
Is an adapter and a fuel gauge what most people do to read their fuel pressures?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
