Proudly Presents:
Import Monster SAU-Vic Deca Motorkhana ROUND 1 of the 2013 CHAMPIONSHIP
When : Saturday 1st June 2013 (7:30am)
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries: 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplementary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
Please re-read the supplementary regulations before entering the event.
Entry Form & Supp. Regs: *********ENTRY FORM*********
Event Schedule:
Results:
ENTRY FORM IS REQUIRED TO BE PUT ONTO THE LIST. PAYMENT IS REQUIRED TO STAY ON THE LIST.
PLEASE FILL OUT FORM COMPLETELY AND CLEARLY.
- if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'.
- All withdrawals will be refunded after the event. Refunds will not be given after 5pm Monday 11th of March.
- Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
- A reminder that anyone who does not have a licence (Cams or AASA) must bring with them, filled out and with $50 correct change, this form:
AASA LICENCE FORM
- GATES WILL BE OPEN AT 730AM. Given the amount of new people can everyone try to be at deca at 0730. The morning sessions are quite long so the earlier we get going, the more time we have for battles in the arvo.
- Grouping requests: If you have anyone that you would like to be grouped with send me a PM and i will try to accommodate.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
Entrant # Name Car
1 IM1 Dave Marinucci Some taxi
2 IM2 Awaiting details Gee Wiz
3 Leon Stapley 180sx
4 Ryan Bell Sil80
5 Jake Lowry S14
6 Hayley Stapley 180sx
7 Bec Pretty Mini
8 Campbell Shobbrook Sil80
9 Matthew Femino 32GTR
10 Kieran Robinson Sil80
11 Luke Shulze 33GTST
12 Juliette Remfrey BRZ
13 Simon Henman 33GTST
14 Tim Watson 86
15 Peter Pham 86
16 Linh Dang S15
17 Daniel Jones S14
18 Robert Dyer 33GTST
19 Michael Glover XR8
20 Russell Cunningham Sil80
21 Josh Hindle 180sx
22 Shane Janssen 33GTR
23 Huy Tran Stag
24 Mark Ryan 33GTST
25 Min Chan Elise
26 Damian Hartin Exige
27 Brad Robinson XR6T
28 Nathan Quelhurst Silvia
29 Paul Stephenson 34GTR
30 Ekat Evo7
31 Nicholas Ganis 86
32 Matt Hindle XR6T
33 Brad Archibold Evo?
34 Andrew Hindle 180sx
35 Jett Benson 180sx
36 Gary Swift 180sx
37 James Jeges AE94
38 Ben Felgate S14
39 Antony Ivancic XR6T
40 Chris Currenti 86
41 Thang Ngo 86
42 Chris Taylor Cressida
43 Michael Bourke Commodore
44 Darren Lang 86
45 Daniel Chin 86
46 Robert Amenta 33GTST
47 Stan Lubinkov Forester
48 Jiyoon Kim 86
49 Samantha Zanotto Mini
50
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
