Hi all, i have this kit ready to install but i havent found hardly any reviews for performance or reliability. Anyone have any evidence if these kits are way to go with your power FC ecu? Just want to make sure it's the right move before going into the trouble.
If not whats the most compatible for your PFC?
Cheers
The good thing is they're very simple to install and all info is shown on the hand commander.
Bad things, they're a very ordinary boost controller, electronics are dated by today's offerings.
They will struggle to maintain steady boost once you get over about 1.2 bar, you need to work on the actuator preload as well to get the best results.
And for my money they're overpriced. I have one for the 32. (in the shed)
They aren't that bad. Mine holds boost alright. Running 18psi
It just takes a bit to setup and then learns for a few runs. Might not be the best but its good if you already have one and don't want any more controllers in the car
I have one running 1.3 to 1.5 bar and i havnt had a problem with it not holding boost.
Took a bit to set up but I recommend them. Especially that you already have it. It's good to just use your hand controller to monitor boost too. Very accurate information I think
Can you increase or decrease the boost via the hand controller?
Planning on getting the pfc and boost controller installed and tuned at the same time when I do all the other turbo and injector mods..so I figured once its done I won't have to do anything to it except drive and enjoy
Keep your reviews coming through, interesting reading....my tuner was the one who got me worried about the pfc controller kit, he doesn't recommended them but that's just one opinion I say....
Sure can. Has 4 different points you can set a max boost setting. Can scroll over to any one of the 4 to reach that boost setting. Also can tweak the settings by increasing or decreasing the solenoid pulse time to fine tune it
all at your hand
Chiizzi, I run the boost kit with my PowerFC controlling an extensively modified twin turbo setup. I've used it since 2005, so I think I can speak with some authority about long term reliability.
It has never had a problem controlling boost to 29psi on the dyno, and I daily drive at 24psi without issue. It has excellent overboost protection and it learns the boost curve if you follow the learning procedure (from memory, 4th or higher gear runs from 1500rpm to 4000rpm - probably best done on the dyno depending on your power level).
It also avoids the need for yet another box. Yes, you can adjust the boost level on the fly with the hand controller. However, I'm not running internal wastegates.
I'm also surprised you, as a native user of this forum since 2007, didn't find this thread in your search - http://www.skylinesaustralia.com/forums/topic/229928-dyno-graphs-comparing-pfc-boost-controll-vs-blitz-idiii/
I have to agree with other posters that there are "better" boost controllers out there, for the *sole* reason that the PFC doesn't apply adjustable closed loop control ("gain") to promote earlier spool. However, this is really just a function of wastegate spring preload, or, in the case of external gates, running appropriate spring pressures. I chose to do the latter (1.2Bar springs) and have had no issues. This fact is also referenced in the linked thread.
Your tuner's opinion is important but he might be the same sort of person telling me that I'd have crap driveability and a dodgy power tune on my setup with a PowerFC, and that I should switch for a (insert ECU du jour here). I'd counter with 530+rwkW for multiple runs, 470rwkW daily driven, pump fuel and WMI, perfect cold and hot starts and excellent driveability out of this "dinosaur" ECU :whistling:
If you want something reliable, easy to set up and neat - I'd say go for it.
Edited by shombre
Im using the pfc boost controller, running 21psi on an internally gated hks2835pros with no problems...
As others have said its one less box, its all on the hand controller. Works fine, i never bother changing the boost setting i use my foot even though i have different boost settings to choose from
better off with another controller like blitz dsbc or greddy profec b unless the physical boost control hardware is going to be spot on (base spring rates, preload etc).
Dont get me wrong the PFC one works well but is not flash when there is any deficiency physically... there are a few tricks in the software but it just doesn't have enough logic to match a stand alone unit.
Any small physical deficiency in the boost control system cannot be rectified with PFC logic whereas a standalone will generally pull it back into check.
i used the pfc kit for a while and it worked pretty well
one less box, good setup, good overboost protection
if you are having issues be mindful of how much boost you want to run and the actuator spring rate
ie dont run a 5psi wastegate spring and expect the pfc boost kit (or any elec controller) to let you run 22psi
choose a reasonable sized spring in the actuator and then bleed a few psi extra via a controller
  • 3 weeks later...
Awesome comments everyone! I'm torn haha!
I'll give the PFC kit a go first and there are any dramas I'll look into something else.
What are the GFB ones like? It's either something like that or a turbosmart eboost st...
  • 2 years later...
Old thread dig
I have a gtt power fc in my c34 stagea. Now I have the factory wiring for the boost solenoid near the afm, and has power at that socket. But, the gtt has a 5 pin pug from the ecu for the boost control harness. I only have a 3 wire harness with a 5 pin plug. There is also 12v at the pin for the solenoid on the ecu socket too. Now do I use the factory wiring, or, do I run wiring to the plug for the ecu and do it that way?
Edited by fmlycar
Use the factory wiring for solenoid
The extra two pins won't drive the solenoid, been there done that
3 wire/ 5 pin harness is for the boost sensor only, the two other pins aren't used on the rb25 neo
Edited by chiksluvit
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
