R33 Gtr N1 wing blade
All parts Australian made.
All parts Carbon fibre, dry laid, vacuum formed and resin infused with a clear gel coat finish.
This gives them a very good weight to strength ratio.
Weight: approx 1.7kg
OEM weight: 2.6kg
If you don't want china stuff look no further as this gear is a quality product and fits first go!
Group buy will go for a month.
Price is $450 or $400 if we get 5 people (plus shipping).
PM me and cash up front if you want in.
As it is a local product it takes two weeks from order to delivery.
Fitted to the car:
Confirmed and Paid:
1- Fatz
2- Goombeh
3- Quinnie
Mate,
I'll be in for one of these if we can be sure of the quality. I had a replica which came on my car and just finished a day at the island, and at 200 clicks, the thing folded under the downforce and acted like a sail once up to those speeds. So I want to make sure this one is strong....
This is mine from what I got the car. Should look the same and its fully adjustable.
The black helps break the colour up a bit which I think makes the car looks better.
As above if the quality and fit is good put me down for one.
Is it possible to get any larger photos of the wing or fitted pics?
Weight saving?
i have not picked mine up yet but being a proper vacuum formed carbon they are much lighter than stock (i was hoping to get five orders so we get the cheaper price before i do as well)
The owner of the australian company that produces these owns an r33 gtr and the fitment is spot on
Pete,
Are these the same/similar as the Just Jap ones?
same style as in a copy of an n1 wing blade.
re-read post two and what happens with the china wings when pushed, as mentioned these are made in Australia and are a top quality item
I will send out pm's to all that are interested and see if we can get the group buy cracking( hopefully at the cheaper price)
pete
yea i think they look hawt on a white r33 gtr
thus the reson i am getting one and the group buy to get it cheaper
Righto, something I should have addressed in the first post:
To confirm people's commitment to the group buy I will be asking for the full payment of $450 up front.
If we get the minimum number of people for the cheaper price then the extra $50 you've paid will go towards the cost of shipping.
I'll have the weight of these confirmed shortly and then I can be sure of the shipping cost. If shipping works out cheaper than 50 I'll refund the difference or if it's more I'll PM you all to send the additional amount (not expecting it to be more but you never know).
Pete
So my wing will be ready in two weeks
Old mate sent me some picks of the wing on a customers car, I've added them to the first post
As you can see the fitment is damn good, Gtr wing on a gts (sweet car whoever owns it)
Righto, weight has now been calculated as approx 1.7kg versus the OEM weight of 2.6kg.
Time to get on it people, I plan to have this group buy closed in 1-2 weeks (preferably closer to 1 week) so we can get an order placed.
PM me if you're in and cash me up.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
