Hey guys,
I forgot my old account name and email with it so I made a new one.
Long story short, I am currently selling my GQ Patrol and am about to buy another skyline.
Most likely an R33 GTS-T and will be going with the fairly common route of unopened rb25 / gt3076r based build.
Now, I have lieing around one of those cheap stainless steel china manifolds and I will be using it in the build. I know it would be wiser to go with a nice steampipe manifold from 6boost/ ETM etc etc but I have one, its free and currently in perfect condition.
I am aware these crack easily but have heard rumour that if you brace and support the manifolds to take alot of the weight off them it can help with preventing this.
I was wondering if anyone who has braced / reinforced a stainless manifold could post up how they did it with pics or similar. It would be great.
I was thinking of just bracing the individual runners themselves as well as bracing the entire manifold to the engine bay or similar to help take the weight off it.
Any info or experiences would be great.
YES I DID SEARCH BTW
Cheers
Hey guys,
and what happens when the engine moves?
lol....i think a brace from the turbo flange on the manifold to the head flange on the manifold can work wonders mate,,,both are solid lumps of steel so joining them kinda makes sense..just make sure nothing is in the way of your turbo lines and your laughing ..
Precisely what ARTZ said. Weld a rod or two from the head flange to the turbo flange and it will help keep the stress off the exhaust runners in between.
Also try and support the dump pipe somewhere so the first half of the exhaust isn't hanging from the turbo, that will also help.
Great idea, I could add an extra hangar to the dump pipe.
I was also thinking of adding a flex piece to the dump pipe, do they cause any restrictions in flow? I would be aiming around the 300rwkw area with the 0.82 GT3076R and supporting mods (fmic, injectors, etc etc).
Also, the mainfold has a wastegate pipe for a 38mm gate. The pipe is not on an ideal angle and I dont want to run a 38mm gate. I am going to get an external wastegate welded onto the turbine housing. If I simply cut the wastegate pipe as short as possible and cap it off will this small pipe create any negative effects on flow in the manifold?
Here is a pic showing where I would cut and weld shut the pipe on the manifold (not my manifold but exact same type).
I use the flex pieces all the time. They work well and provide a nice amount of 'give' for the exhaust system, however I put it right at the bottom of the dump pipe where it connects to the rest of the exhaust system.
If possible use the next size up for your dump pipe if it is still to be fabricated, especially if you are going to plumb the waste gate back into it somewhere. So use a 3.5" dump pipe with a 3" system from there back.
You can cut it off close to where it merges with the other pipes, however leave a little bit out, perhaps 3/4" worth and tig a cap over it. Or you could just bolt a cover plate onto the flange, that will work fine too. It wont really make any noticeable difference. With the welding of the support rods, make sure you use stainless and make sure it is tig welded on. If it is mild steel and mig'd it will more then likely crack off and potentially cause more stress risers.
Just cap off the flange and do as r33_racer said, use a flexible bellow for the exhaust. The reason so many of those manifolds crack quickly is because they're solid mounted to the exhaust which acts like a big lever on the manifold.
Don't try and weld bracing on it, it an just make things worse.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
