Hey all,
Posting on behalf of a mate.
He has a 33 GTST and has the following mods (track only car)
1000cc injectors
Power Fc
Profec 2 boost controller
Walbro E85 pump
Cam gears and cams
z32
Stripped the car completly.
Runs slicks on the rear
Looking at what turbo and what top mount manifold to use?
Plus what forward facing to use?
Will a bigger throttle body be needed?
What he is setting it up for is 1/8th mile dragging.
Hes after a turbo for excellent response and mid range power.
The engine will be rebuilt if / when it goes bang.
Not chasing any specific power goal, just decent times over the 1/8th mile
What options are there?
Only needs to pull hard from a standing start to the end of an 8th mile!
Any other mods needed to?
https://www.sau.com.au/forums/topic/425145-rb-25-turbo-choices/
most cars on the strip are built for bigger power and even plenty of these street cars are the same and have much bigger setups. In yous instance you are talking 1/8th so the question has to be asked is why?
whats the point of the 1/8th? where you heading with the build?
whats quick on 1/8th is going to be usless (or just about) on 1/4
to be honest because the only venue i have to drive my car is an 1/8 mile track.
plus the car will be used for the occasional hill climb and the sorts.
So its more about response and excellent mid range, without running out of puff
Its just hard reading and getting ideas as there is nothing on here for what im looking for.
Its a strickly track only car also, so dont car about a rough idle for cams or a pig to drive etc as its out on the track a handful times a year etc etc
Gtx3071 on e85. Plazmaman plenum with his 72mm throttle body. Should be good for 350rwkw with killer response. Nitrous is awesome set up correctly. Unsure why people dislike the idea of using it. What's a nitrous kit worth now days?
I don't personally have that setup but micko on here did and from all reports pulled like a freight train all the way through. Maybe someone that actually know micko and went in it can explain more? Um I think he made 335rwkw on e85 internal gate version .82! Also on the stock mani aswell.
Lol @ top end, its an 1/8 mile you wont get half way though third gear,
just get a hiflow..stock plenum and everything...it will be just as quick for what you need...
the money you save put towards your suspension setup, tyres and practice runs because that's what will make you fast...
Anyway I know nobody will take any notice of this post so potato...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
